Starter relay or no starter relay, Been reading up for an hour and still don't know!! |
David Stowers |
Feb 22 2014, 05:06 AM
Member Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
On two occasions recently on pulling onto my driveway after a long journey my car won't restart after turning off to unlock the garage door. Luckily I can then just push the car in but with a European tour booked in the summer I'd like to sort the problem.
When I get back in after opening the garage the lights on the dash dim when I turn the key to start but there is no click. 20 minutes later it will start right up. Is this the problem that will be solved by a hot start relay kit or just a good old fashioned sticky solenoid? I'd rather do just the relay or just replace the solenoid so which is it? Thanks guys |
ClayPerrine |
Feb 23 2014, 10:00 AM
Life's been good to me so far..... Group: Admin Posts: 15,950 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I tried all the different hot start fixes over the last 28 years, ford relay, bosch relay, rebuilt bosch starters... everything.
Now I don't have a relay on either 914, and never have a hot start issue. 1. I cleaned all the grounds in both cars. 2. I put a new ground cable on them. 3. I use a high torque, aftermarket starter. The high torque starters spin faster, and use less pull in current for the solenoid. |
Lo-Fi Version | Time is now: 27th December 2024 - 05:04 AM |
