73 fuel pump mounting question, It has been too long !!!!!!! |
David_S |
Jan 20 2008, 01:05 AM
Member Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region |
I started tinkering with my project again a few days ago, and am in the process of getting the engine bay back together. Only problem so far is I had to replace the right engine shelf, and I cant remember how the fuel pump mounts ! I attached a pic of the area where the Haynes manual shows it to be, but the pic in the manual isn't the greatest. Also in the pic, what mounts in the slotted J shaped bracked above the motor mount? It has been too long ago since I tore this thing apart and I screwed up and didn't take enough pictures !!!!!! TIA
Attached image(s) |
914_teener |
Feb 24 2014, 12:13 AM
914 Guru Group: Members Posts: 5,250 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
No problem with the fuel pump mounted on the firewall if that is what you mean.
I have run my fuel level down to the reserve level all the time. I have cleaned my tank btw. |
Shindog1961 |
Feb 24 2014, 12:23 AM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
No problem with the fuel pump mounted on the firewall if that is what you mean. I have run my fuel level down to the reserve level all the time. I have cleaned my tank btw. That's exactly what I meant. Glad to know. I agree that sounds preferable to under the fuel tank. |
Lo-Fi Version | Time is now: 7th January 2025 - 12:15 PM |
