73 fuel pump mounting question, It has been too long !!!!!!! |
David_S |
Jan 20 2008, 01:05 AM
Member Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region |
I started tinkering with my project again a few days ago, and am in the process of getting the engine bay back together. Only problem so far is I had to replace the right engine shelf, and I cant remember how the fuel pump mounts ! I attached a pic of the area where the Haynes manual shows it to be, but the pic in the manual isn't the greatest. Also in the pic, what mounts in the slotted J shaped bracked above the motor mount? It has been too long ago since I tore this thing apart and I screwed up and didn't take enough pictures !!!!!! TIA
Attached image(s) |
ConeDodger |
Jan 21 2008, 12:53 PM
Apex killer! Group: Members Posts: 23,863 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
In a properly maintained car you should not experience vapor lock. I suspect that Porsche relocated the fuel pump because they couldn't count on people properly maintaining their cars. In the back it is close to a source of heat and possible ignition for those cars that owners maintain poorly.
At the pressure in an EFI system vapor lock shouldn't occur with a properly maintained vehicle. It is easy enough to relocate if you have the proper mount but a pain to replace it and the fuel filter. That said, mine is up front. But it came that way... |
Dtjaden |
Feb 24 2014, 09:47 AM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
In 1973 I had a new 914. I was in Minnesota at that time. It would vapor lock frequently whenever the temp went above 85. My solution at the time was to install a second low pressure pump in the front trunk. So it was not just maintenance issues that caused the problem.
Never a problem with my new 1976. I would put the pump in the front as I am going to do when I convert my current 73 back to FI. In a properly maintained car you should not experience vapor lock. I suspect that Porsche relocated the fuel pump because they couldn't count on people properly maintaining their cars. In the back it is close to a source of heat and possible ignition for those cars that owners maintain poorly. At the pressure in an EFI system vapor lock shouldn't occur with a properly maintained vehicle. It is easy enough to relocate if you have the proper mount but a pain to replace it and the fuel filter. That said, mine is up front. But it came that way... |
Lo-Fi Version | Time is now: 7th January 2025 - 11:54 AM |
