Bursch Vs. Monza / Header Systems, ...Fitting OBXes, and other header system recommendations... |
MikeInMunich |
Feb 24 2014, 04:27 PM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Hi Guys,
I recently acquired a Bursch over Ebay and have an almost new Monza as well. The car is a 2.0 with OBX headers. There are three factors (that I know of) for my consideration: Looks: Monza wins Sound: Which one will sound cooler? Please post your opinions! Performance: Which will offer (slightly) better HP, if either at all? Opinions! Thanks! Mike in Munich (IMG:style_emoticons/default/smilie_flagge6.gif) |
'73-914kid |
Feb 24 2014, 05:50 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
How did you get an OBX header to fit on your engine? They're not even close to lining up with the exhaust ports. Also, if you have a header, the Bursch, Monza, or stock mufflers will not fit as they are designed to fit only with the factory heat exchangers.
You need to do more research. |
Maltese Falcon |
Feb 25 2014, 01:01 AM
Advanced Member Group: Members Posts: 4,819 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
How did you get an OBX header to fit on your engine? They're not even close to lining up with the exhaust ports. Also, if you have a header, the Bursch, Monza, or stock mufflers will not fit as they are designed to fit only with the factory heat exchangers. You need to do more research. + 1 on that note ! factor #4, the obx 4 into 1 (counterfeit copy) exhaust header does in fact terminate into a single 3 bolt , 2.5" flanged collector, totally not compatible with any brand muffler that interconnects to the Type 4 HB's. Mike, congrats on getting that obx on your engine, you are one of the rare few ! If you plan to keep that header on the 2.0, mate it to a decent 2.5" i.d. high flow muffler. Marty |
MikeInMunich |
Feb 25 2014, 01:08 AM
Thanks for that input Marty. I will let you, too, know what's up. If Ed in Sun Valley did indeed "get" something on where others may have failed, only he deserves the credit. I'm damm curious now myself, but Ed's sleeping right now...
Lo-Fi Version | Time is now: 26th September 2024 - 05:20 PM |
