> Steve's 73 1.7 Restoration Thread
Steve_R
post Jun 23 2013, 11:32 PM
Hi, I would like to introduce myself and share my project. I’m Steve, I live in San Diego and I picked up this 1973 1.7 914 about a year ago. It was in great shape with no rust and had been sitting in a garage for the past 13 years. My plan is to restore it to its original condition. At this point I think the car is about 50% done.
The car had door guards riveted to the sides and I had them welded up. One of the first things I did when I got the car was to build a dolly to be able to work on the suspension and make it easy to move it around the garage. It’s made from 4 X 4s and plywood and it took about 4 hours to build. If you don’t have a wood saw Home Depot will cut the 4 X 4s and plywood to the correct length. There are lag screws on top of the vertical posts that stick up ½” that fit into the 4 jack points cups under the car. This keeps the car from falling off. Also, I removed the engine before I put the car on it. To get it up there I used some cement blocks, 4 jack stands and 2 scissor jacks.
Over the past year I’ve learned a lot from reading your posts and now I would like to give back some of the knowledge I’ve learned.
Attached File(s)
saigon71
post Mar 5 2014, 08:36 AM
Impressive work...very clean and meticulous! (IMG:style_emoticons/default/beerchug.gif)
Steve_R
post Mar 5 2014, 10:14 PM
The front bumper had a rust hole that needed some patching. I cut out the section and welded in a piece. I made a crude form out of wood to form a slight curve in the piece before I welded it in place. I also welded up the bumper guard holes. After a lot of grinding and filing it turned out really good.
Also, the front valance needed a lot of work. I built a frame out of 2x4s to support it while i did the body work. I used wood screws to hold it to the support.
After a long search, I found the perfect semi gloss paint. It's called 2K urethane underhood black from Eastwood. I think it matches the original semi gloss black perfectly.
ndfrigi
post Mar 5 2014, 10:35 PM
QUOTE(Steve_R @ Mar 5 2014, 08:14 PM) *
wait!!!! Is that front bumper that was repaired is the same bumper that was installed in the car? Metal bumper to chrome bumper?
Steve_R
post Mar 5 2014, 10:53 PM
Yes, it is the same bumper. I forgot to mention that I took it to the chrome plater and had him strip off the chrome so I could weld on it.
ndfrigi
post Mar 5 2014, 11:48 PM
QUOTE(Steve_R @ Mar 5 2014, 08:53 PM) *
Sir Steve, that is an amazing job! It seems you prepare to do that than buying a clean chromed bumper. Is it cheaper that way sir? Can you share how much for the chrome plating and what shop in San Diego?
Thanks in advance and God bless!
Noel
Steve_R
post Mar 6 2014, 12:15 AM
QUOTE(ndfrigi @ Mar 5 2014, 09:48 PM) *
Noel
Noel, I think it was a lot cheaper. It was a lot of work on my part but, I really enjoy the process.
Since I already had the bumper the only cost was chroming it and the $20 I paid the muffler shop to weld it. Don at Escondido Plating did the chrome and he charged me $400 for the front bumper He also plated both bumpers, shifter, inside and outside door handles and the seat belt loops.
In the end I think it was cheeper than buying another one and having it rechromed.
ndfrigi
post Mar 6 2014, 11:40 AM
QUOTE(Steve_R @ Mar 5 2014, 10:15 PM) *
Noel
Meaning Sir Steve, $400 for all those? (2 bumpers, shifter, handles and belt loops). Can I chrome plate a bumper which is originally a painted bumper? Thus it has same metal thickness for those original chromed bumper and painted bumper?
Any plans of doing a 914 guys BBQ fellowship at your place soon?
Steve_R
post Mar 6 2014, 11:43 PM
QUOTE(ndfrigi @ Mar 6 2014, 09:40 AM) *
Noel
Noel, It was $400 for just the front bumper. I can't remember how much the other parts were but the rear bumper was around $350. He charged me a little more for the front because he needed to add a little more copper to fill in some of the small pits from welding.
Steve_R   Steve's 73 1.7 Restoration Thread   Jun 23 2013, 11:32 PM
JawjaPorsche   Good luck with your project. Looks like you have ...   Jun 24 2013, 05:32 AM
Steve_R   I finally finished the paint job. Here in Californ...   Aug 15 2013, 10:01 PM
zambezi   Great job. I hope my home paint job comes out tha...   Aug 16 2013, 09:54 PM
Cairo94507   That looks terrific! I hope you post more pic...   Aug 17 2013, 07:55 AM
rick 918-S   Nice work :wttc:   Aug 18 2013, 05:19 AM
jimkelly   thanks for the details and product list. looks ni...   Aug 18 2013, 05:41 AM
bulitt   Wow! Love the canoe!   Aug 18 2013, 06:34 AM
FourBlades   What happened to welding in 30 rust repair panels?...   Aug 18 2013, 07:18 AM
watsonrx13   Excellent work. Can you show some pics of the pain...   Aug 18 2013, 07:51 AM
Steve_R   Rob, I didn't use a paint booth. I painted it ...   Aug 18 2013, 09:11 AM
CptTripps   I was planning on getting one of these to do the p...   Mar 3 2014, 07:25 PM
ndfrigi   Hi Steve, Can you share a picture(s) of your car ...   Mar 3 2014, 07:45 PM
cconcepcion   +1 on the canoe! on a side note….you mus...   Mar 3 2014, 07:49 PM
Steve_R   So, here's an update. Since my last post i...   Mar 4 2014, 12:09 AM
ndfrigi   Wow beautiful! Thanks for sharing the update...   Mar 4 2014, 12:19 AM
Steve_R   More pics   Mar 4 2014, 08:13 AM
Steve_R   Applied undercoating and relocated the fuel pump a...   Mar 4 2014, 08:17 PM
type47   ... and relocated the fuel pump and filter to und...   Mar 5 2014, 06:18 AM
Steve_R   [quote name='Steve_R' post='2006143' date='Mar 4 ...   Mar 5 2014, 08:07 AM
Steve_R   [quote name='Steve_R' post='2006143' date='Mar 4...   Mar 5 2014, 08:18 AM
KELTY360   [quote name='Steve_R' post='2006319' date='Mar 5 ...   Mar 7 2014, 08:06 AM
Steve_R   [quote name='Steve_R' post='2006319' date='Mar 5...   Mar 9 2014, 11:18 AM
Steve_R   Started working on the interior this week. I bough...   Mar 27 2014, 11:31 PM
Steve_R   The next project was to make a wire harness for th...   Jun 3 2014, 10:09 PM
Steve_R   The gauges were in bad shape so I sanded them down...   Jun 3 2014, 10:15 PM
ThePaintedMan   WOW. Really impressive work Steve. Nice to see som...   Mar 4 2014, 08:29 AM
wndsnd   WOW. Really impressive work Steve. Nice to see so...   Mar 4 2014, 08:41 PM
r3dplanet   The hell you say! The 1.7 should never be cons...   Mar 4 2014, 09:36 PM
ben*james   Cracking me up! :agree: 1.7 is worthy :wor...   Mar 4 2014, 09:40 PM
saigon71   Impressive work...very clean and meticulous! ...   Mar 5 2014, 08:36 AM
Steve_R   The front bumper had a rust hole that needed some ...   Mar 5 2014, 10:14 PM
ndfrigi   The front bumper had a rust hole that needed some...   Mar 5 2014, 10:35 PM
Steve_R   Yes, it is the same bumper. I forgot to mention th...   Mar 5 2014, 10:53 PM
ndfrigi   Yes, it is the same bumper. I forgot to mention t...   Mar 5 2014, 11:48 PM
Steve_R   Yes, it is the same bumper. I forgot to mention ...   Mar 6 2014, 12:15 AM
mepstein   [quote name='ndfrigi' post='2006733' date='Mar 5 ...   Mar 6 2014, 07:17 AM
ndfrigi   [quote name='ndfrigi' post='2006733' date='Mar 5 ...   Mar 6 2014, 11:40 AM
Steve_R   [quote name='ndfrigi' post='2006733' date='Mar 5...   Mar 6 2014, 11:43 PM
Steve_R   One of the more challenging projects was to rebuil...   Mar 7 2014, 12:04 AM
mepstein   Just WOW!   Mar 5 2014, 10:27 PM
Shindog1961   Nice! Really like the dolly, how did you get t...   Mar 6 2014, 12:03 AM
Cairo94507   Steve that is some outstanding work. Bumper looks...   Mar 7 2014, 07:22 AM
Philip W.   :trophy: Very nice!, enjoyed seeing it all com...   Mar 7 2014, 07:53 AM
ndfrigi   Hi Again Steve, A real amazing job and beautiful ...   Jun 4 2014, 01:43 AM
Steve_R   It's been a while since I've posted any pi...   Oct 14 2014, 08:51 PM
mepstein   WOW!   Oct 14 2014, 09:00 PM
altitude411   Sa-Weet! Really nice work. Congrads on being...   Oct 14 2014, 09:09 PM
stevegm   Wasn't there a picture on 914world of this car...   Oct 14 2014, 09:25 PM
Steve_R   Wasn't there a picture on 914world of this ca...   Oct 14 2014, 10:02 PM
stevegm   [quote name='stevegm' post='2097874' date='Oct 14...   Oct 14 2014, 10:11 PM
trojanhorsepower   Wow!   Oct 14 2014, 10:15 PM
Cairo94507   Car looks beautiful! :first:   Oct 15 2014, 07:29 AM
CptTripps   Great job on that interior. Very well done.   Oct 15 2014, 11:04 AM
Steve_R   So now that I have about 1,000 miles on my car it...   Oct 22 2014, 08:08 PM
Steve_R   Some pics   Dec 16 2014, 06:38 PM
Cairo94507   I love your car :trophy: What's up with tha...   Dec 16 2014, 07:20 PM
turk22   Absolutely beautiful job, just love the way it cam...   Dec 16 2014, 07:21 PM
Larmo63   Gawd, is there anything you CAN'T do?? You did...   Dec 16 2014, 08:21 PM
bigkensteele   Stunning! I admire your ingenuity and will be...   Dec 16 2014, 08:32 PM
G e o r g e   That 914 is a thing of beauty. Great job   Dec 16 2014, 10:27 PM
Cuda911   Holey Macaroni! Wow!! That is such an...   Dec 17 2014, 12:26 AM
Amphicar770   Wow! Beautiful work all around. I wish I had...   Jun 30 2016, 09:34 AM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 9th January 2025 - 09:04 AM
