Sfreeman615 |
Member ![]() ![]() Group: Members Posts: 146 Joined: 23-February 14 From: Nashville,TN Member No.: 17,033 Region Association: South East States ![]() |
Hey guys, well here it is. My 71 1.7! I'm anxious to get started. First thing I want to do is sand the body down and start the primer process. First Question, what grit sandpaper should I use to begin with to start to get some surface rust off as well as the old paint? I want to get it down to metal and go from there, inside and out. The car also came with 2 trans and I want to know how I know which one came with the car? Sorry for all of the stupid questions, but I'm a nube! Also gonna post a link to more pictures in a post to follow this. I will also add the VIN number to the database on here...
Bob L. |
Senior Member ![]() ![]() ![]() Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region ![]() |
Re: The Transmissions,
If one has the input shaft at the tail (tail shifter) that would be the correct type for your year. Can't say if it is original to your car. If you have one with the shifter input on the side towards the rear (side shifter) you may want to use it as it will probably shift better. It would require a different shift rod after the firewall. You could use the other for parts if they are in good shape. (IMG:style_emoticons/default/welcome.png) |
Lo-Fi Version | Time is now: 24th June 2024 - 06:30 AM |
