heat exchanger, a.k.a. header? |
opera guy |
Aug 7 2004, 05:00 AM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
Regarding the part known as "Heat Exchanger," does that include the exhaust manifold (header)?
Can the heat exchanger be bought without buying the header? i see quite a number of the people here mention Stainless Steel heat exchangers, but its never referred to as header or exhaust manifold, why? just porsche lingo? conversely, when you buy SS heat exchanger, are you getting the header portion as well? Since i need both parts (if they are indeed separate) are there OEM or aftermarket ones available? if so, where is the best source (Pelican's out) or am i stuck with getting hand-me-downs? (not that there's anything wrong with it) this is for a 73 2.0, btw, thanks in advance |
watsonrx13 |
Aug 7 2004, 06:44 AM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Hey Opera Dude, you might want to check the item again, it is the SS heat exchanger BRACKET, not the heater/header that you thought.
The add's description is 'Bracket (Bolts To Rear Tran Case, 1 Required) '. But you were right, it was too good to be true. (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 26th September 2024 - 11:46 AM |
