replacing ignition switch question |
rosenfe |
Mar 15 2014, 06:18 PM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
on my 73 ive gotten steering wheel off,turn signal wiper switch out,two screwss at igniton switch,put key in tumbler to on,but cant get tumbler to come out.what do i do?
poorsche914 |
Mar 15 2014, 06:55 PM
T4 Supercharged Group: Members Posts: 3,093 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Have you unplugged the rear electrical ?
From the Pelican tech article: Now, unplug the rear, electrical portion of the ignition switch. At this point, you should be able to insert your key, twist, and pull out the entire assembly, as shown in Figure 11. Hope that helps. (IMG:style_emoticons/default/driving.gif) |
rosenfe |
Mar 15 2014, 07:15 PM
Have you unplugged the rear electrical ? From the Pelican tech article: Now, unplug the rear, electrical portion of the ignition switch. At this point, you should be able to insert your key, twist, and pull out the entire assembly, as shown in Figure 11. Hope that helps. (IMG:style_emoticons/default/driving.gif) that did it,got the switch out,i did not realize the whole metal cylinder with switch on end comes out,had to use a bit of pulling force.thanks for your help. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:45 PM |
