D-jet troubleshooting, Only one item left on my list! |
saigon71 |
Mar 16 2014, 04:06 PM
Advanced Member Group: Members Posts: 2,006 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
My 1974 2.0 D-jet is running very strong, but there were two lingering issues with the FI that I wanted to address over the winter:
1. A severe idle "hunt." The engine would rush up to about 1200 RPM, then nearly stall...repeat cycle. 2. Every once in a while the car would buck, most notably at highway speeds...it wasn't bad, just annoying. Last week I installed a new circuit board in the TPS purchased from Dave Sprinkle a few years back. It was calibrated according to the Pelican tech article using an ohmmeter. I took a 210 mile road trip over the weekend to test things out. The car now idles perfectly through the entire warm-up sequence. Thanks Dave! (IMG:style_emoticons/default/beerchug.gif) The problem is that I still have the same bucking issue. All my research points to the TPS. Any suggestions on what to check next? |
larss |
Mar 17 2014, 06:32 AM
Member Group: Members Posts: 431 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
My 1974 2.0 D-jet is running very strong, but there were two lingering issues with the FI that I wanted to address over the winter: 1. A severe idle "hunt." The engine would rush up to about 1200 RPM, then nearly stall...repeat cycle. .... I also got this cycling after putting 1911cc together, worst during warm up. I found that if I put an extra 50 to 100 Ohms in serial with the 270 Ohm ballast resistor for the CHT sensor, the cycling was almost eliminated. The extra resistance makes the engine run somewhat richer (the CPU Believes the Engine is colder than what it is). /Lars S |
Lo-Fi Version | Time is now: 28th December 2024 - 03:27 AM |
