saigon71 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region ![]() ![]() ![]() |
My 1974 2.0 D-jet is running very strong, but there were two lingering issues with the FI that I wanted to address over the winter:
1. A severe idle "hunt." The engine would rush up to about 1200 RPM, then nearly stall...repeat cycle. 2. Every once in a while the car would buck, most notably at highway speeds...it wasn't bad, just annoying. Last week I installed a new circuit board in the TPS purchased from Dave Sprinkle a few years back. It was calibrated according to the Pelican tech article using an ohmmeter. I took a 210 mile road trip over the weekend to test things out. The car now idles perfectly through the entire warm-up sequence. Thanks Dave! (IMG:style_emoticons/default/beerchug.gif) The problem is that I still have the same bucking issue. All my research points to the TPS. Any suggestions on what to check next? |
jsayre914 |
Speed Up !!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region ![]() |
Bob,
I fixed this issue by removing the trigger points from the dizzy and cleaning them. Give it a try. I am not sure if they are available new (I couldnt find any) but if you find a new set, Get one for me too. (IMG:style_emoticons/default/beerchug.gif) Good Luck! |
Lo-Fi Version | Time is now: 26th June 2024 - 03:47 AM |
