Fuel starvation when maxing out? |
David Stowers |
Feb 10 2014, 07:01 AM
Member Group: Members Posts: 99 Joined: 28-June 12 From: UK Member No.: 14,613 Region Association: None |
My 914 is running a 1.8 (ish!) 40 Dellortos and recently recorded 111BHP and 121lbft of torque after a carb set up so yesterday I went to have a little thrash about.
A couple of times when the traffic cleared I really kept my foot flat down and pushed to over 100MPH on a slight uphill. It was still pulling strongly for a few seconds then seemed to lose power and splutter slightly. I backed off and it returned to normal. It seemed like the carbs emptied as if the fuel pump couldn't keep up. I had the heater on and the rich oily aroma changed to a hot sharp smell like it suddenly ran lean. It's running the small square facet pump mounted up front near the master cylinder. Any ideas please Thanks David |
Intubator |
Mar 17 2014, 05:25 PM
Newbie Group: Members Posts: 18 Joined: 12-January 14 From: Maryland Member No.: 16,878 Region Association: North East States |
If the problem occurs at a consistent RPM regardless of load you may actually have a faulty distributor RPM limiting rotor, bad points or worn distributor point contacts...
Lo-Fi Version | Time is now: 20th October 2024 - 06:53 AM |
