Sfreeman615 |
Member ![]() ![]() Group: Members Posts: 146 Joined: 23-February 14 From: Nashville,TN Member No.: 17,033 Region Association: South East States ![]() |
Hey guys, well here it is. My 71 1.7! I'm anxious to get started. First thing I want to do is sand the body down and start the primer process. First Question, what grit sandpaper should I use to begin with to start to get some surface rust off as well as the old paint? I want to get it down to metal and go from there, inside and out. The car also came with 2 trans and I want to know how I know which one came with the car? Sorry for all of the stupid questions, but I'm a nube! Also gonna post a link to more pictures in a post to follow this. I will also add the VIN number to the database on here...
Sfreeman615 |
Well,I have been slammed stripping the car down getting ready for media blasting and primer! I'm trying to get done stripping everything off so I can take it early next week. Once it has been media blasted and primed, then it will go have the floor pans welded in and the rust repaired before heading to Knoxville for the new engine build!
I was thinking while I have it in this stage, should I go ahead and replace the struts, calipers and rotors? The car hasn't run in 16 years, so I'm sure it needs them. If so, what struts have you guys had good luck with, there's so much money going into everything else, thinking of just doing the KYB (OEM) replacements. Also, while I'm doing this, should I do the 5 lug conversion? |
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
Well,I have been slammed stripping the car down getting ready for media blasting and primer! I'm trying to get done stripping everything off so I can take it early next week. Once it has been media blasted and primed, then it will go have the floor pans welded in and the rust repaired before heading to Knoxville for the new engine build! I was thinking while I have it in this stage, should I go ahead and replace the struts, calipers and rotors? The car hasn't run in 16 years, so I'm sure it needs them. If so, what struts have you guys had good luck with, there's so much money going into everything else, thinking of just doing the KYB (OEM) replacements. Also, while I'm doing this, should I do the 5 lug conversion? I have a good set of front Boge I can bing you. So spend the money on some good rears. Pull the calipers and send them to Eric at PMB. No options on the brakes. He is the best. His brakes save my car. |
Sfreeman615 |
I have a good set of front Boge I can bing you. So spend the money on some good rears. Pull the calipers and send them to Eric at PMB. No options on the brakes. He is the best. His brakes save my car. [/quote] You da man! Wanna go in on a welder together! hahahahaha |
Mblizzard |
[quote name='Sfreeman615' date='Mar 21 2014, 04:57 PM' post='2014083']
I have a good set of front Boge I can bing you. So spend the money on some good rears. Pull the calipers and send them to Eric at PMB. No options on the brakes. He is the best. His brakes save my car. [/quote] You da man! Wanna go in on a welder together! hahahahaha [/quote] I would like that but the wife sends you a dirty look on the welder. (IMG:style_emoticons/default/chair.gif) |
Lo-Fi Version | Time is now: 24th June 2024 - 06:20 AM |
