2270 Build Thread |
2270 Build Thread |
McMark |
Feb 4 2014, 12:00 PM
I'm building this 2270 and I thought this would be a good one to document. I'm going to try and cover every little aspect of the build, although I'm not necessarily going to break down every process into a step by step.
I'm starting with a 1.7 'W' case. I did a quick line bore check and it's a nice STD case. But more on that later when I actually measure the line bore accurately. Case Preparation - In this section I'm covering all the modifications and inspections to be done on the bare case. Threaded Gallery Plugs, Resurface Oil Filter Mount I used my slide hammer setup to pull the original gallery plugs. I'm just doing the 'normal five'. In this picture also shows the oil filter mount face - I pull the studs and true the surface up to ensure a good, leak-free seal. HV Oil Pump I have a Schadek oil pump that I've cut in half to mark the case for 'port matching' the oil pump. The ports on the case are smaller than the oil pump, so this simply eases the transition. I use a carbide cutter for aluminum in a pneumatic die grinder to carefully open up the holes. Cleaning Stud Threads I chased all the M8x1.25 studs on the case. This eases installation, but also ensures more accurate torque. Any fastener that has a specific torque value should have clean threads. The rust/dirt/sealant/etc on the surface will make the fastener harder to turn, which means you're getting a slightly false torque reading. You'll see the head studs have all been removed. I don't use a tap or die to clean the head stud or the case threads because I've seen this result in loose head studs. I don't touch this parts of the case, and I use a wire wheel on the bench top grinder to clean the threads without risk of removing material. |
McMark |
Mar 23 2014, 10:08 PM
What I charge for an engine is what I charge. This thread will detail some of the processes that go into the build. If you think it's a crazy price -- that's okay. Shop around. I'm sure you'll find someone cheaper. The trick, you'll find, is to figure out why their engine is so much cheaper and what steps they're skipping to save a few bucks.
I don't mean to sound dismissive, but I learned a long time ago that I can't afford to stay in business by pricing things by what people wish they cost. I price things by what it takes to build them and to do it right. |
Lo-Fi Version | Time is now: 24th September 2024 - 12:50 PM |
