McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I'm building this 2270 and I thought this would be a good one to document. I'm going to try and cover every little aspect of the build, although I'm not necessarily going to break down every process into a step by step.
I'm starting with a 1.7 'W' case. I did a quick line bore check and it's a nice STD case. But more on that later when I actually measure the line bore accurately. Case Preparation - In this section I'm covering all the modifications and inspections to be done on the bare case. Threaded Gallery Plugs, Resurface Oil Filter Mount I used my slide hammer setup to pull the original gallery plugs. I'm just doing the 'normal five'. In this picture also shows the oil filter mount face - I pull the studs and true the surface up to ensure a good, leak-free seal. ![]() HV Oil Pump I have a Schadek oil pump that I've cut in half to mark the case for 'port matching' the oil pump. The ports on the case are smaller than the oil pump, so this simply eases the transition. I use a carbide cutter for aluminum in a pneumatic die grinder to carefully open up the holes. ![]() ![]() Cleaning Stud Threads I chased all the M8x1.25 studs on the case. This eases installation, but also ensures more accurate torque. Any fastener that has a specific torque value should have clean threads. The rust/dirt/sealant/etc on the surface will make the fastener harder to turn, which means you're getting a slightly false torque reading. You'll see the head studs have all been removed. I don't use a tap or die to clean the head stud or the case threads because I've seen this result in loose head studs. I don't touch this parts of the case, and I use a wire wheel on the bench top grinder to clean the threads without risk of removing material. ![]() |
Larmo63 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California ![]() |
Is this is a streetable engine, or a full race engine?
ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
Now it's $10K?? This is a streetable engine, or a full race engine? I understand the costs, I was just voicing what (maybe) a few others were thinking. If you're going to build a 2270, you're probably going to put your foot in it many times. It is at that time that you will be wondering if it will stay together and was it built right. You will have forgotten what you paid for it, but if Mark does it, you will know that it was built by someone who knows what he is doing and that is what matters. When my AX times are generally lower than even late model 911s, I know I made the right decision. |
hedgehog |
Member ![]() ![]() Group: Members Posts: 50 Joined: 6-June 06 From: Central Calif Member No.: 6,169 Region Association: Central California ![]() |
Now it's $10K?? This is a streetable engine, or a full race engine? I understand the costs, I was just voicing what (maybe) a few others were thinking. If you're going to build a 2270, you're probably going to put your foot in it many times. It is at that time that you will be wondering if it will stay together and was it built right. You will have forgotten what you paid for it, but if Mark does it, you will know that it was built by someone who knows what he is doing and that is what matters. When my AX times are generally lower than even late model 911s, I know I made the right decision. now i see how you beat me out there.... (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:40 PM |
