2270 Build Thread |
2270 Build Thread |
McMark |
Feb 4 2014, 12:00 PM
I'm building this 2270 and I thought this would be a good one to document. I'm going to try and cover every little aspect of the build, although I'm not necessarily going to break down every process into a step by step.
I'm starting with a 1.7 'W' case. I did a quick line bore check and it's a nice STD case. But more on that later when I actually measure the line bore accurately. Case Preparation - In this section I'm covering all the modifications and inspections to be done on the bare case. Threaded Gallery Plugs, Resurface Oil Filter Mount I used my slide hammer setup to pull the original gallery plugs. I'm just doing the 'normal five'. In this picture also shows the oil filter mount face - I pull the studs and true the surface up to ensure a good, leak-free seal. HV Oil Pump I have a Schadek oil pump that I've cut in half to mark the case for 'port matching' the oil pump. The ports on the case are smaller than the oil pump, so this simply eases the transition. I use a carbide cutter for aluminum in a pneumatic die grinder to carefully open up the holes. Cleaning Stud Threads I chased all the M8x1.25 studs on the case. This eases installation, but also ensures more accurate torque. Any fastener that has a specific torque value should have clean threads. The rust/dirt/sealant/etc on the surface will make the fastener harder to turn, which means you're getting a slightly false torque reading. You'll see the head studs have all been removed. I don't use a tap or die to clean the head stud or the case threads because I've seen this result in loose head studs. I don't touch this parts of the case, and I use a wire wheel on the bench top grinder to clean the threads without risk of removing material. |
Larmo63 |
Mar 23 2014, 09:47 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Is this is a streetable engine, or a full race engine?
blackmoon |
Mar 24 2014, 04:42 PM
Member Group: Members Posts: 153 Joined: 27-May 08 From: Cal Bay Area Member No.: 9,106 Region Association: None |
Now it's $10K?? This is a streetable engine, or a full race engine? I understand the costs, I was just voicing what (maybe) a few others were thinking. Conedogger's right, money well spent, I have a 2270 in my 914, plenty of torque and not to radical for the street. Its the motor the car should have had. |
ConeDodger |
Mar 25 2014, 09:56 AM
Apex killer! Group: Members Posts: 23,633 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Now it's $10K?? This is a streetable engine, or a full race engine? I understand the costs, I was just voicing what (maybe) a few others were thinking. Conedogger's right, money well spent, I have a 2270 in my 914, plenty of torque and not to radical for the street. Its the motor the car should have had. Porsche/VW would still be building a derivative of the 914 today if they had put a 2270 or at least a 2056 in the 914 to begin with. The 2432 Mark and I built that is soon going into John's car, is probably more motor than you need. Just my opinion, but if you aren't concerned about originality and some definitely should be, all stockish rebuilds should be 2056 at least and 2270 is a more complicated but very nice motor. Mark builds very nice streetable motors. Every guy would like to spend the night with Katy Perry, but live with her? Not so much. Mark's 1.7 turbo experiment is a success in every way. When he ups the displacement and puts a bigger turbo on it, it is going to fly... I'm really looking forward to seeing this project run. He charges what he charges because he is worth AT LEAST THAT MUCH! |
Lo-Fi Version | Time is now: 27th June 2024 - 06:09 PM |
