Front hub/new Fuchs help |
bmendel |
Mar 28 2014, 04:07 PM
Member Group: Members Posts: 66 Joined: 3-July 03 From: Bay Area, CA Member No.: 877 |
I just switched wheels to a new set of Fuchs alloys, but had some trouble with the center cap. The grease cap that came off the front hub was the black cap in the pictures below, and I want to fit the silver caps on the Fuchs, as pictured. Should the Fuchs cap fit over the black cap, or is it supposed to replace the black cap. Seems like the black cap would provide much better grease in/dirt out protection, but the silver center cap does not fit over the black cap. Thought? Wrong silver caps? Supposed to replace black cap? Thanks.
Qarl |
Mar 28 2014, 04:30 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I just switched wheels to a new set of Fuchs alloys, but had some trouble with the center cap. The grease cap that came off the front hub was the black cap in the pictures below, and I want to fit the silver caps on the Fuchs, as pictured. Should the Fuchs cap fit over the black cap, or is it supposed to replace the black cap. Seems like the black cap would provide much better grease in/dirt out protection, but the silver center cap does not fit over the black cap. Thought? Wrong silver caps? Supposed to replace black cap? Thanks. Grease cap stays attached to hub. The silver aluminum hub cover is attached to the wheels and is for decoration only (over the grease cap). |
bmendel |
Mar 28 2014, 04:56 PM
Grease cap stays attached to hub. The silver aluminum hub cover is attached to the wheels and is for decoration only (over the grease cap). Does this mean I have the wrong silver caps, as they do not fit over the black grease caps, or do I need to seat the black cap further in with a piece of wood and a BFH |
Lo-Fi Version | Time is now: 15th January 2025 - 07:58 AM |
