> Front hub/new Fuchs help
bmendel
post Mar 28 2014, 04:07 PM
I just switched wheels to a new set of Fuchs alloys, but had some trouble with the center cap. The grease cap that came off the front hub was the black cap in the pictures below, and I want to fit the silver caps on the Fuchs, as pictured. Should the Fuchs cap fit over the black cap, or is it supposed to replace the black cap. Seems like the black cap would provide much better grease in/dirt out protection, but the silver center cap does not fit over the black cap. Thought? Wrong silver caps? Supposed to replace black cap? Thanks.Attached Image Attached Image
Qarl
post Mar 28 2014, 04:30 PM
Shriveled member
QUOTE(bmendel @ Mar 28 2014, 06:07 PM) *
Grease cap stays attached to hub.
The silver aluminum hub cover is attached to the wheels and is for decoration only (over the grease cap).
bmendel
post Mar 28 2014, 04:56 PM
QUOTE(Qarl @ Mar 28 2014, 03:30 PM) *
Does this mean I have the wrong silver caps, as they do not fit over the black grease caps, or do I need to seat the black cap further in with a piece of wood and a BFH
Qarl
post Mar 28 2014, 05:02 PM
Shriveled member
You mean the grease caps are sticking through the hole in the Fuchs too much once the wheel is mounted?
If so, then perhaps not in far enough.
Again, the aluminum caps attach to the wheel. Pressure fit to the inside center hole of the fuchs rum. Use a board and rubber mallet and tap them in squarely.
Qarl
post Mar 28 2014, 05:03 PM
Shriveled member
QUOTE(Qarl @ Mar 28 2014, 07:02 PM) *
found something similar on the bird site
http://forums.pelicanparts.com/porsche-914...e-dust-cap.html
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 15th January 2025 - 08:00 AM
