> What do you have for chassis stiffening?
What is neccessary to race on slicks
Engman/ long kit [ 22 ] ** [25.00%]
Patrick Motorsprts kit/ Rear engine area [ 2 ] ** [2.27%]
Both [ 4 ] ** [4.55%]
Cage only [ 21 ] ** [23.86%]
All of the above [ 10 ] ** [11.36%]
None [ 12 ] ** [13.64%]
Other [ 16 ] ** [18.18%]
What is chassis stiffening? [ 1 ] ** [1.14%]
Do you race on slicks? (I guess its not racing if your not)
yes [ 34 ] ** [38.64%]
no [ 54 ] ** [61.36%]
Total Votes: 176
Guests cannot vote
Justinp71
post Sep 29 2008, 07:14 PM
I put some more horsepower in my car, so far I have just autocrossed it on street tires. I have the bolt in roll bar that has the mid bar going to the floor.
Besides that my chassis is stock and I am wondering what I should do for more re-enforcement... so I can comfortably run on slicks.
Below is a photo of the roll bar. I don't consider the roll bar to give to much chassis stiffening, but it just might help with cracking the longs.
Edit: I mainly just use the car for street and the occasional Autocross or DE
Joe Ricard
post Apr 1 2014, 05:53 AM
CUMONIWANNARACEU
Geeze I was reading this thinking wtf did I do? Man that was a long time ago.
The snap oversteer I think is less now because you took some of the "spring" out of the chassis. I noticed the same thing in my old car, just point it in and it went exactly where I wanted.
Randal
post Apr 1 2014, 01:35 PM
QUOTE(Joe Ricard @ Apr 1 2014, 04:53 AM) *
Right, there is a video, of the Medford Spring Enduro from last year on YouTube. https://www.youtube.com/watch?v=7XTxvcpka5w
At about 1:06 you see me enter a corner a bit fast, with a poor line, coming off the straight. Check how far the car rotated and then came back with a simple off throttle steering correction. Somewhat unusual for a 914, hey?
I agree with you that the stiffer chassis does help as well.
Justinp71   What do you have for chassis stiffening?   Sep 29 2008, 07:14 PM
SirAndy   I've got a full cage but it's not tied int...   Sep 29 2008, 09:04 PM
sww914   Judging from the cars that I've fixed, if you ...   Sep 29 2008, 11:40 PM
dlestep   ...I am welding the rear stiffening kit on my car ...   Sep 29 2008, 11:42 PM
Justinp71   ...I am welding the rear stiffening kit on my car...   Oct 1 2008, 10:38 AM
Joe Ricard   Engman longs and a roll bar tied to rear shock tow...   Sep 30 2008, 05:57 AM
Justinp71   Thanks guys! <_< It sounds like for t...   Sep 30 2008, 07:07 PM
dakotaewing   I have Brad Maures (sp) Outer Long kit, and Chris...   Sep 30 2008, 10:10 PM
Justinp71   I have Brad Maures (sp) Outer Long kit, and Chris...   Sep 30 2008, 11:05 PM
jcd914   OK I guess maybe I should not be voting since the ...   Sep 30 2008, 11:59 PM
Justinp71   Well Thanks for posting anyhow Jim! When you ...   Oct 1 2008, 10:37 AM
the4u2   how much flex is to much? have one that flex 8mm ,...   Oct 1 2008, 01:07 PM
J P Stein   There are a pee pot load of do-dads sold to make y...   Oct 2 2008, 08:58 AM
9146986   The last full project car I built had Brad Mayeur...   Oct 2 2008, 08:59 AM
naro914   I've been racing or DEing our 914 since 1994, ...   Oct 2 2008, 08:14 PM
Justinp71   Does the Engman kit reduce body flex? Or just keep...   Oct 3 2008, 04:20 PM
jcd914   Does the Engman kit reduce body flex? Or just kee...   Oct 11 2008, 08:56 PM
ConeDodger   Does the Engman kit reduce body flex? Or just kee...   Dec 4 2008, 10:47 PM
John   An area that seems to crack and few discuss is whe...   Oct 23 2008, 08:28 PM
J P Stein   Tieing in the longs to the towers is gud. Tieing i...   Dec 7 2008, 02:30 PM
Justinp71   Well my conclusion for my more street oriented car...   Jan 14 2009, 01:20 AM
9146986   I forgot to add that I welded up all the seams I c...   Jan 14 2009, 10:06 AM
Justinp71   Did you race or a/x the car that you are describin...   Jan 14 2009, 12:22 PM
9146986   The customer that I built the car for did autocros...   Jan 14 2009, 12:37 PM
Justinp71   No cage, correct?   Jan 14 2009, 01:53 PM
charliew   What makes these little cars attractive is their l...   Jan 16 2009, 08:48 AM
Simon Tibbett   I am new to 914's and looking into getting one...   May 29 2009, 10:13 AM
jt914-6   I have Brad's long. kit, GT kit, boxed trailin...   Jun 1 2009, 08:50 AM
jhadler   In the first photo there, it looks like you are dr...   Jun 1 2009, 02:11 PM
jt914-6   Josh, yes I'm using the cooler heat for the wi...   Jun 1 2009, 03:25 PM
J P Stein   After bonking my helmeted haid on my cage halo, I ...   Jun 8 2009, 05:47 PM
Joe Ricard   JP would you please show me your engine lid? Lik...   Jun 9 2009, 05:51 AM
J P Stein   I don't have a pic of it, go figure. I made a ...   Jun 9 2009, 07:38 AM
Joe Ricard   Metal? My car will have bare minimum of metal....   Jun 9 2009, 09:15 AM
J P Stein   Metal? My car will have bare minimum of metal...   Jun 9 2009, 11:13 AM
Joe Ricard   Yea PM me with your thoughts. I'm a looking a...   Jun 9 2009, 11:26 AM
J P Stein   Yea PM me with your thoughts. I'm a looking ...   Jun 9 2009, 02:51 PM
Chris Hamilton   Has anyone measured the amount of flex they had be...   Aug 30 2009, 05:36 PM
Britain Smith   Didn't measure it, but we felt it in JP's ...   Sep 17 2009, 11:54 AM
Joe Ricard   I can 3 point lift my car and it stays level. get...   Dec 9 2009, 07:11 AM
Chris Hamilton   Joe, My car does that with an autopower rollbar bo...   Dec 12 2009, 03:55 PM
J P Stein   It doesn't take an engineering degree to see ...   Dec 12 2009, 07:01 PM
Randal   It doesn't take an engineering degree to see...   Dec 12 2009, 10:05 PM
J P Stein   I've taken JP's approach on adding fro...   Dec 13 2009, 11:06 AM
Randal   It doesn't take an engineering degree to se...   Mar 31 2014, 07:59 PM
Chris Hamilton   It doesn't take an engineering degree to see...   Dec 13 2009, 03:02 PM
J P Stein   I've been building stuff for 40 odd years....m...   Dec 13 2009, 04:00 PM
Joe Ricard   Chris there is no way your bolt in autopower cage ...   Dec 13 2009, 05:14 PM
J P Stein   BTW, our trip down to your house at Marina was qua...   Dec 13 2009, 05:56 PM
Chris Hamilton   JP, it will be fun to see how Andrew and Britain d...   Dec 13 2009, 07:05 PM
J P Stein   Brit is headed down that way for the SD National T...   Dec 14 2009, 08:30 AM
Joe Ricard   Raced in the little pond yesterday. PCA had an ev...   Dec 14 2009, 10:52 AM
Randal   Raced in the little pond yesterday. PCA had an e...   Mar 31 2014, 08:02 PM
Joe Ricard   Geeze I was reading this thinking wtf did I do? ...   Apr 1 2014, 05:53 AM
Randal   Geeze I was reading this thinking wtf did I do? ...   Apr 1 2014, 01:35 PM
smokey   My Lilbasterd Gets much stiffer wen chancing any...   Jan 5 2015, 08:17 PM
ThePaintedMan   Dafuq?   Jan 6 2015, 07:51 AM
Bullethead   How did this thread get reanimated? Last post was ...   Sep 6 2023, 09:45 PM
d914   egman inner longs tangering racing rear console su...   Oct 9 2023, 01:13 PM
mlindner   I had a full roll bar cage for many years. The las...   Dec 1 2023, 04:35 PM
brant   I had a full roll bar cage for many years. The la...   Dec 2 2023, 08:31 AM
mlindner   Thanks brant. Was not intended for full racing. D...   Dec 4 2023, 09:02 AM
Charles Freeborn   A 911 I'd be concerned about straying too far ...   Jan 6 2024, 01:24 AM
brant   We learned a lot about rules during the build. so ...   Apr 26 2024, 01:43 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:42 AM
