Sfreeman615 |
Member ![]() ![]() Group: Members Posts: 146 Joined: 23-February 14 From: Nashville,TN Member No.: 17,033 Region Association: South East States ![]() |
Hey guys, well here it is. My 71 1.7! I'm anxious to get started. First thing I want to do is sand the body down and start the primer process. First Question, what grit sandpaper should I use to begin with to start to get some surface rust off as well as the old paint? I want to get it down to metal and go from there, inside and out. The car also came with 2 trans and I want to know how I know which one came with the car? Sorry for all of the stupid questions, but I'm a nube! Also gonna post a link to more pictures in a post to follow this. I will also add the VIN number to the database on here...
Sfreeman615 |
Just ordered parts for the new engine from DRD Racing. Parts list includes:
-DRD L6 Racing Heads Based of a new AMC head casting, oval exhaust ports., DRD L6 Type 4 head is for a hot street car / track / off road car. Power output, depending on your combo. CNC ported ,44mm x 38mm, multi angle job. New DRD SS 44X38mm valves, dual springs, hd valve guides, all hardware included. This CNC L6 port combo retains bottom end torque, with excellent mid-range and high-end pull to 6500 rpms. 94mm standard bore size. These heads have standard 4 bolt intake flanges, and standard type 4 spark plug locations. Sold as pair of 2 heads. These heads are built to order. -5DRD Type 4 , 2316CC stroker parts kit *New Forged 4340 Type 4, 80mm crankshaft, dynamic balanced by DRD and inspected by DRD. *1 set of 4 ,Keith Black, 96mm Stoker pistons, with ring kit, and 22mm pistons pins, clips.Piston set Balanced by DRD. *1 set of 4 DRD 96mm Cast iron cylinders, Heat treated and nirtadied, better quality than stock OEM cylinder. *1 Set of 4 DRD H Beam 5.352 Rods,22mm pin, ARP2000 bolts, Balanced by DRD *1set of Silver Line steel backed Type 4 main bearings. *1 Set of rod bearings. -Web Cam type4 86 Camshaft .423 lift at valve, 270 advertized duration, 234 duration@.050 lift, to be used with stock rocker. Good all around street cam, provides a wide range of power on 2.0 and larger platforms. To be used with dual carbs and nice exhaust system. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:30 AM |
