Type IV conversion update.... |
fuch toy |
Apr 30 2003, 08:54 AM
Unregistered |
Looks like the Fiberwerks unit is the one I am going with.
The dual electric fan cowlings will not require any machining of the block, will be actuated by a thermostat, allowing oil temps to get to 180F before turning on. The wiring/thermostat is similar to the unit I used on the rocket for the oil cooler that I robbed from a 930 Turbo. Pretty solid, I had no problems in three years of use. I will be using a 90 amp one wire GM alternator so the electrical load won't be overwhelming. Just ordered the conversion flywheel from Kennedy....decided to go that route as the 914 flywheel from Rimco cut down seemed "iffy"....200mm kevlar "mikey proof" clutch and heavy duty Sachs pressure plate. The GT flares arrived last week, the 993 wheels are getting powder coated, ordering rubber today. Anyone wanna come over and help sawzall some fender well cut outs? When was the last time anyone got the opportunity to sawzall a 356???? Z |
Britain Smith |
Apr 30 2003, 10:38 AM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I would love to see your car during the conversion process...I will be moving out there in June. Anyway, what transmission are you using in the 356. I am doing the same in my 912 with a 5-speed 901 tranny and I thought that I could use the stock type-IV flywheel with a 914 clutch and it would work fine. Do you think that I need or should consider a different flywheel?
What did you decide to do on the headers? Are you going to try to regain heat in your car at any point? -Britain |
Lo-Fi Version | Time is now: 21st June 2024 - 02:41 PM |
