Joseph Mills |
on a Sonoma diet now... ![]() ![]() ![]() Group: Members Posts: 1,482 Joined: 29-December 02 From: Oklahoma City, OK Member No.: 39 ![]() |
If I buy it, I'll probably have to sleep in it. (IMG:style_emoticons/default/biggrin.gif)
Joseph Mills |
Wow Rich, that's pretty good! Here's some details.
2.2l six out of a 71 911T, 40IDA webers with MSD. Sideshift trans with 911 pull style clutch. Quick-six mounting bar and solid trans mounts. Front fiberglass fenders and bumper-1 piece removable with dzus fasteners Front brake are steel "A" calipers 76 911 turbo Rear brakes are "M" calipers 84 Carrera,vented rotors Adj. brake bias valve in the cockpit. Front struts are green bilstein 935 coil-over struts with raised spindles Front torsion bars 22mm and plastic bushings in the a-arms Rear shocks are yellow konis with 2 1/2" adj. coil-overs-200lbs springs Chassis stiffening kit with additional stiffening in the rear trunk Boxed trailing arms with plastic bushings Peterson dry sump oil tank mounted in front trunk ~5 gallons Oberg remote oil filter in the front trunk |
Lo-Fi Version | Time is now: 25th June 2024 - 08:29 PM |
