Tach problems, 6 conversion |
GulleyGulley |
Apr 13 2014, 07:03 AM
Member Group: Members Posts: 67 Joined: 12-March 12 From: CNY Member No.: 14,243 Region Association: None |
Installed a 86 3.2 into my car with a tach from the donor. Everything works but the tach. It reads about double what it should. Any ideas why it's off?
JStroud |
Apr 13 2014, 08:11 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
He posted the tach is out of the donor, so I'm assuming its a 911 tach.
You shouldnt need a tach adapter, maybe hooked up wrong (IMG:style_emoticons/default/confused24.gif) |
Qarl |
Apr 13 2014, 08:32 AM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
He posted the tach is out of the donor, so I'm assuming its a 911 tach. You shouldnt need a tach adapter, maybe hooked up wrong (IMG:style_emoticons/default/confused24.gif) Are you using a distributor or different type of signal, like a distributor-less ignition? The signal patterns and voltages can be different. |
Lo-Fi Version | Time is now: 28th June 2024 - 11:16 PM |
