> Discharge of Battery, drawing 1.97 amp but can't find where
smarens
post Apr 13 2014, 03:43 PM
-I am getting a constant discharge on my battery
-I wired my meter in series between positive cable and the positive post on battery (when battery is fully charged)
-it shows draw of 1.97 amps
-have a 1975 with 66k miles and most everything stock from what I can tell
-I have taken the troubleshooting as far as I can and now stumped
-in the picture if you see the two red wires crimped on one terminal that is where my draw is coming from
-thought that went to relay board, so I have unplugged all (3) of my relays, both fused, voltage regulator and 3-wire plug going to alternator, still can't get rid of the draw
-anyone know where those two wires go? or has anyone seen this before?
thanks,
smarens
post Apr 13 2014, 03:52 PM
sorry should have stated the two red wires with yellow tape are the exact ones causing the issue
smarens   Discharge of Battery   Apr 13 2014, 03:43 PM
904svo   those red wires go to the fuse panel   Apr 13 2014, 03:48 PM
smarens   I pulled each fuse one at a time from under the da...   Apr 13 2014, 03:50 PM
smarens   sorry should have stated the two red wires with ye...   Apr 13 2014, 03:52 PM
bulitt   Pull your fuses one at a time until the draw stops...   Apr 13 2014, 03:52 PM
messix   unplug the voltage regulator on the relay board. i...   Apr 13 2014, 03:59 PM
smarens   -pulled fuses one at a time, nothing changed -unpl...   Apr 13 2014, 04:02 PM
Dr Evil   Since you checked the fuses individually, and the ...   Apr 13 2014, 04:21 PM
smarens   the wires go down under/thru tins it appears, any ...   Apr 13 2014, 04:27 PM
Dr Evil   Not without my book and some time. You have to tra...   Apr 13 2014, 04:47 PM
76-914   2 reds go to the 14 pin plug on the relay board #1...   Apr 13 2014, 04:51 PM
smarens   2 reds go to the 14 pin plug on the relay board #...   Apr 13 2014, 06:45 PM
smarens   great thanks I'll start looking, they both sta...   Apr 13 2014, 04:52 PM
Dr Evil   Good thing I refreshed my screen....I almost typed...   Apr 13 2014, 04:55 PM
FourBlades   When did this start? Could it be related to somet...   Apr 13 2014, 04:56 PM
smarens   just started 1 week ago, I have only had the car f...   Apr 13 2014, 04:59 PM
Dr Evil   What John mentions is good. If you pull a fuse at ...   Apr 13 2014, 05:07 PM
r_towle   Do you have a stereo? Amp?   Apr 13 2014, 05:24 PM
smarens   Do you have a stereo? Amp? stereo yes, no amp   Apr 13 2014, 06:44 PM
stugray   Put your multi meter on Ohms and "audible con...   Apr 13 2014, 06:25 PM
smarens   Put your multi meter on Ohms and "audible co...   Apr 13 2014, 06:44 PM
Mike Bellis   One of the red wires goes to the fuse panel. The o...   Apr 13 2014, 06:30 PM
smarens   One of the red wires goes to the fuse panel. The ...   Apr 13 2014, 06:47 PM
Tom   Your picture shows the red wires giving the curren...   Apr 14 2014, 06:21 AM
smarens   thanks guys got it, traced it back to the fuse pan...   Apr 19 2014, 07:12 AM
JStroud   It's always the last place you look :lol4:   Apr 20 2014, 09:06 AM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 06:29 PM
