Discharge of Battery, drawing 1.97 amp but can't find where |
smarens |
Apr 13 2014, 03:43 PM
Member Group: Members Posts: 69 Joined: 15-March 14 From: Michigan Member No.: 17,121 Region Association: None |
-I am getting a constant discharge on my battery
-I wired my meter in series between positive cable and the positive post on battery (when battery is fully charged) -it shows draw of 1.97 amps -have a 1975 with 66k miles and most everything stock from what I can tell -I have taken the troubleshooting as far as I can and now stumped -in the picture if you see the two red wires crimped on one terminal that is where my draw is coming from -thought that went to relay board, so I have unplugged all (3) of my relays, both fused, voltage regulator and 3-wire plug going to alternator, still can't get rid of the draw -anyone know where those two wires go? or has anyone seen this before? thanks, Attached thumbnail(s) |
Dr Evil |
Apr 13 2014, 04:21 PM
Send me your transmission! Group: Members Posts: 23,036 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Since you checked the fuses individually, and the regulator, it sounds like you have a shorted wire. Almost 2A is not a small amount of current and a short to ground would explain this. Check the wires that are the cause for a short to ground. Disconnect both ends. to do this.
Lo-Fi Version | Time is now: 6th January 2025 - 06:28 PM |
