914 lays down..., a newbie needs some advice... |
splashfx |
Aug 9 2004, 02:57 PM
Dismember Group: Members Posts: 37 Joined: 1-July 03 From: Harrison, AR Member No.: 875 |
Hey guys and ladies,
I have had my 914 for over a year now, but hate to admit that it's spent most of that time in storage. Last Friday I decided to drive it to work (about 45 miles one way). It went to work and almost all the way home before suddenly (and I do mean suddenly) two cylinders stopped firing. I suspect that it has fouled the plugs - but I haven't had a chance to check it yet. Okay, so I trailered it home and it's now in the shop. I was planning to check the plugs, and do a valve adjustment (...just because I know it hasn't been done while I've had it). I don't believe that the problems have anything to do with the electrical - I put on a Pertronix Ignitor and new plugs and wires last summer. Also, I plan to look over the vacuum on the motor and see if I can find any leaks. I'm also suspect of the fuel injection system. I'm almost convinced to rip it off and put a set of carbs on it. It doesn't seem to idle correctly, and quite often seems to be very rich (black smoke). Any other educated guesses? I would love an expert opinion in this matter, since I'm a complete novice to these air-cooled devils and especially on the FI. Thanks guys (IMG:style_emoticons/default/beerchug.gif) |
Dave_Darling |
Aug 9 2004, 06:41 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There are some L-jet articles over on http://www.type2.com ; the later Buses also used L-jet.
On the brake pedal thing--you may have sticking pedal cluster bushings. The most common cause for that is them swelling due to brake fluid leaks from a failing master cylinder. Check for missing paint (and present rust!) around the pedal cluster. You may need to re-bush the cluster. (NOTE: If you go with the bronze bushing kit that is commonly available, DO NOT USE the supplied roll-pin! Use your original if you can save it, or get the proper VW/Porsche part or get a good multi-layer one locally!) --DD |
Lo-Fi Version | Time is now: 28th June 2024 - 04:24 AM |
