914 lays down..., a newbie needs some advice... |
splashfx |
Aug 9 2004, 02:57 PM
Dismember Group: Members Posts: 37 Joined: 1-July 03 From: Harrison, AR Member No.: 875 |
Hey guys and ladies,
I have had my 914 for over a year now, but hate to admit that it's spent most of that time in storage. Last Friday I decided to drive it to work (about 45 miles one way). It went to work and almost all the way home before suddenly (and I do mean suddenly) two cylinders stopped firing. I suspect that it has fouled the plugs - but I haven't had a chance to check it yet. Okay, so I trailered it home and it's now in the shop. I was planning to check the plugs, and do a valve adjustment (...just because I know it hasn't been done while I've had it). I don't believe that the problems have anything to do with the electrical - I put on a Pertronix Ignitor and new plugs and wires last summer. Also, I plan to look over the vacuum on the motor and see if I can find any leaks. I'm also suspect of the fuel injection system. I'm almost convinced to rip it off and put a set of carbs on it. It doesn't seem to idle correctly, and quite often seems to be very rich (black smoke). Any other educated guesses? I would love an expert opinion in this matter, since I'm a complete novice to these air-cooled devils and especially on the FI. Thanks guys (IMG:style_emoticons/default/beerchug.gif) |
Ctrout |
Aug 9 2004, 06:52 PM
Member Group: Members Posts: 377 Joined: 20-May 04 From: Mountain Home, ID. Member No.: 2,091 |
I'll guarantee you that your pedal won't return because your pedal cluster bushings need to be replaced. Mine did the same thing. Rebuilt the cluster with new bushings and now it feels better than new. Cheap and very simple fix. (besides the part about getting a rusted clutch pedal off.)
Lo-Fi Version | Time is now: 28th June 2024 - 04:20 AM |
