patssle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None ![]() |
For my 3.0L SC motor with Weber carbs to a 901 transmission - I'm planning on a new Kennedy 228mm flywheel and 228mm Stage II pressure plate.
My existing 215mm 914 4 spring clutch disc still has life left on it - can this be used at all? I've seen some notes that 215mm can be used on 228mm flywheels...is this true or do I need the 228 with 6 springs for a /6 engine? Thanks. |
Lo-Fi Version | Time is now: 29th June 2024 - 12:06 AM |
