Strange MPS issue, Lew's car |
914itis |
Apr 15 2014, 04:22 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I am helping Brian with Lew's car. As most of you may know, it is a 2056 with djet.
The car was running fine, he drive it to CT one day and when he came back he noticed that the MPS was hanging. The car starts to run on 3 cylinders with #4 not firing. We checked for spark and injectors they are all fine, but if you remove spark wire #4, it had no effect. The strange thing is if you elevate the mps about 6 inches up, it's all fine, even that 4th cyl works. All the electrical wires on the unit are fine (IMG:style_emoticons/default/confused24.gif) ? Dies the 2056 uses 1.7 or 2.0 MPS? He would like to make it to Hershey. |
SLITS |
Apr 16 2014, 11:17 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
You need a vacuum pump and volt/ohm meter ..............
See if it holds 15" of vacuum for 5 mins. 4 pins on the MPS. Should be 90 Ohms between the two outer pins and 350 Ohms between the two inner ( or could be visa versa, don't remember but the values are correct). Check each pin for continuity to ground (the case). |
Lo-Fi Version | Time is now: 31st October 2024 - 07:30 PM |
