Gasoline Smell....where is it coming from?...6 conversion, Update 5/18 |
billh1963 |
Apr 18 2014, 11:55 AM
Car Hoarder! Group: Members Posts: 3,404 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
When driving the car (engine is a 2.2L 6 with triple Webers) I frequently smell gas. This is with the targa on or off. The smell comes and goes...it's not consistent; however, it always occurs
If I stop the car and check around the car (with the engine running) I don't smell it. With the engine running I have checked everywhere and don't see or smell anything. No drips or puddles under the car, around the carbs, etc. I have checked connections on the fuel pump and nothing there. I have thought of two possibilities: 1. Leaking fuel line in the tunnel (which I should smell all the time...right?) 2. Fumes coming into the cockpit from the engine compartment. Any other thoughts? Update: 5/3 Drove the car extensively today and, as usual, the gas smell comes and goes. Stopped while the smell was strong and checked around the carbs...dry Looked under the car...dry Opened the trunk...no smell. Even pulled the gear shift to see if there was a gas smell in the tunnel...nothing The only thing I see is this line is hanging out in space...could the smell be coming from here? Should I cap it or does it need to connect somewhere? Remember...this car has triple webers...it's not fuel injected. |
Spoke |
Apr 18 2014, 12:09 PM
Jerry Group: Members Posts: 7,079 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I had a come-and-go fuel odor in the car. Traced it to an oozing fuel line connection under the fuel tank. Never leaked to a puddle, couldn't smell it when investigating under the front hood.
The area wasn't wet but showed signs of seepage. It only takes one small drop of fuel to really smell up the interior. You may want to lift the tank out to investigate. |
billh1963 |
Apr 18 2014, 12:15 PM
I had a come-and-go fuel odor in the car. Traced it to an oozing fuel line connection under the fuel tank. Never leaked to a puddle, couldn't smell it when investigating under the front hood. The area wasn't wet but showed signs of seepage. It only takes one small drop of fuel to really smell up the interior. You may want to lift the tank out to investigate. That's on my list if all else fails. It's over half full so really don't want to drain the tank if I can help it. |
Lo-Fi Version | Time is now: 31st October 2024 - 10:23 PM |
