> Gasoline Smell....where is it coming from?...6 conversion, Update 5/18
billh1963
post Apr 18 2014, 11:55 AM
Car Hoarder!
When driving the car (engine is a 2.2L 6 with triple Webers) I frequently smell gas. This is with the targa on or off. The smell comes and goes...it's not consistent; however, it always occurs
If I stop the car and check around the car (with the engine running) I don't smell it. With the engine running I have checked everywhere and don't see or smell anything. No drips or puddles under the car, around the carbs, etc. I have checked connections on the fuel pump and nothing there.
I have thought of two possibilities:
1. Leaking fuel line in the tunnel (which I should smell all the time...right?)
2. Fumes coming into the cockpit from the engine compartment.
Any other thoughts?
Update: 5/3
Drove the car extensively today and, as usual, the gas smell comes and goes. Stopped while the smell was strong and checked around the carbs...dry
Looked under the car...dry
Opened the trunk...no smell.
Even pulled the gear shift to see if there was a gas smell in the tunnel...nothing
The only thing I see is this line is hanging out in space...could the smell be coming from here?
Should I cap it or does it need to connect somewhere?
Remember...this car has triple webers...it's not fuel injected.
billh1963
post May 3 2014, 03:41 PM
Car Hoarder!
Update...see first post
billh1963   Gasoline Smell....where is it coming from?...6 conversion   Apr 18 2014, 11:55 AM
veekry9   When driving the car (engine is a 2.2L 6 with trip...   Apr 18 2014, 12:07 PM
billh1963   When driving the car (engine is a 2.2L 6 with tri...   Apr 18 2014, 12:13 PM
Spoke   I had a come-and-go fuel odor in the car. Traced i...   Apr 18 2014, 12:09 PM
billh1963   I had a come-and-go fuel odor in the car. Traced ...   Apr 18 2014, 12:15 PM
bulitt   Do you still have the charcoal canister and expans...   Apr 18 2014, 12:18 PM
toolguy   I would not drive the car until you KNOW 100% that...   Apr 18 2014, 12:18 PM
Qarl   What type of fuel lines do you have? Gas with eth...   Apr 18 2014, 02:14 PM
john77   I have exactly the same problem with my 6 conversi...   Apr 18 2014, 04:08 PM
billh1963   I have exactly the same problem with my 6 convers...   Apr 18 2014, 04:40 PM
76-914   I'm with Zach on this one.   Apr 18 2014, 05:01 PM
billh1963   Update...see first post   May 3 2014, 03:41 PM
wobbletop   As toolguy mentioned, check the tank overflow line...   May 3 2014, 04:02 PM
billh1963   As toolguy mentioned, check the tank overflow lin...   May 3 2014, 06:37 PM
JStroud   The "line hanging in space" would have g...   May 3 2014, 11:02 PM
Cap'n Krusty   It's not like I really read all the somewhat c...   May 3 2014, 11:16 PM
billh1963   It's not like I really read all the somewhat ...   May 4 2014, 09:32 AM
mepstein   so im guessing with the car running, more air is p...   May 4 2014, 08:02 AM
McMark   Do not cap the lines from the tank. If you seal i...   May 4 2014, 09:52 AM
JStroud   Bill, unless they removed them you should have two...   May 4 2014, 10:00 AM
larryM   X2 on Jeff's comments - but you never told us ...   May 4 2014, 09:01 PM
GeorgeRud   On my conversion, I attached one vent line to the ...   May 5 2014, 08:06 AM
Cap'n Krusty   On my conversion, I attached one vent line to the...   May 5 2014, 08:18 AM
billh1963   Put a "T" in the drain hose and connecte...   May 18 2014, 05:54 PM
- Lo-Fi Version Time is now: 31st October 2024 - 10:25 PM
