Seing double?, Now tested double D-jet performance! |
larss |
Jan 10 2014, 01:35 AM
Member Group: Members Posts: 429 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia |
Anybody tried double D-jet air boxes and TB before?
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.lsmteknik.se-10787-1389339349.1.jpg) /Lars S |
larss |
May 5 2014, 10:47 PM
Good ideas JamesM!
How do you match the vanagon TB to the D-jet TPS? /Lars S |
JamesM |
May 6 2014, 11:12 AM
Senior Member Group: Members Posts: 1,997 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Good ideas JamesM! How do you match the vanagon TB to the D-jet TPS? /Lars S You install megasquirt!!! (IMG:style_emoticons/default/smile.gif) The throttle shaft size and shape are the same, though the vanagon TB the TPS side of the shaft does not extend as far out, looks like there would be enough to engage the d-jet TPS though. You need a plate under the TPS to be able to mount/set the angle correctly (same thing I had to do with the TPS I used on my Megasquirt setup). The Vanagon TB pulls in a different direction, so you need the throttle cable arm off of a 1.8 TB as well, basically just undo the nut holding the spring and arm on the 1.8TB and it all just bolts directly the Vanagon 2.1 TB. Got to love how interchangeable VW stuff is! |
Lo-Fi Version | Time is now: 28th November 2024 - 09:50 PM |
