oil filler cap gasket |
era vulgaris |
May 12 2014, 04:16 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
On a 1.7 d-jet, is there supposed to be any sort of cork gasket or rubber seal on the filler cap itself? My car doesn't have one and I think it could be the cause of my high idle issue.
If so, does anyone have a part number for it? Is this it? Model year/FI system isn't specified so I thought I'd ask. http://www.pelicanparts.com/catalog/SuperC..._pg4.htm#item17 Also, I don't have these two seals: numbers 1 and 8 in the pic. Does anyone have a part number for these? http://www.autoatlanta.com/porsche-parts/h...;section=114-05 |
era vulgaris |
May 12 2014, 07:13 PM
Right.
But is the manifold vacuum not also pulling gases from the crankcase through the pcv valve? So wouldn't an air leak around the oil filler act as a vacuum leak when the pcv valve is open, since it would be sucking outside air in through the leaks in the oil filler? And wouldn't that be why my idle comes within spec when I disconnect the pcv-to-plenum hose? That's the point I'm trying to understand. Also, anyone have info or sources for the #1 and 8 seals on that parts diagram? |
bdstone914 |
May 12 2014, 09:21 PM
bdstone914 Group: Members Posts: 4,673 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Right. But is the manifold vacuum not also pulling gases from the crankcase through the pcv valve? So wouldn't an air leak around the oil filler act as a vacuum leak when the pcv valve is open, since it would be sucking outside air in through the leaks in the oil filler? And wouldn't that be why my idle comes within spec when I disconnect the pcv-to-plenum hose? That's the point I'm trying to understand. Also, anyone have info or sources for the #1 and 8 seals on that parts diagram? The connection from the oil filter breather should go to the air filter from the hose diagram I looked at. The only vacuum connections I saw from the plenum were for the MPS and vacuum pot on the distributor. Can you show us what connection on the plenum the pic valve is connected? Edit: I was wrong. Looks like the pvc hose does go to the plenum. Could the pcv valve be stuck open? Again some pictures would help. |
Lo-Fi Version | Time is now: 28th September 2024 - 07:11 AM |
