Speedo angle drive, do they go bad? |
SirAndy |
May 12 2014, 09:51 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
After replacing my broken speedo cable (torn in half) my speedo still wasn't working.
So i disconnected it at the angle drive and used a drill to drive the cable and the speedo worked just fine. I then tried to turn the angle drive spade by hand and i was able to turn it while it was making a crunchy sounds. I don't think i'm supposed to be able to turn this by hand. Anyone know for sure? (IMG:style_emoticons/default/idea.gif) PS: Can i replace this with the oil in the transmission? What if i get the car at an steep angle, would it still leak? |
Bob L. |
May 12 2014, 09:55 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
There's an inner drive and then the outer "angle drive" My angle drive went bad and I replaced it. No fluid worries. Fine now. Probably your problem.
Lo-Fi Version | Time is now: 25th June 2024 - 07:57 PM |
