> Basic parts list
partwerks
post May 12 2014, 08:12 PM
In terms of cost, here’s a basic parts list from Renegade:
$8500 LS3 engine package 430hp (480hp $500 more)
$2600 914 LS basic kit
$2200 914 LS Boxster LS clutch and adapter upgrade
$250 Starter
$1200 Heavy Duty Axles
$595 Rear Trans mount
$750 Misc. Hydraulic Clutch Conversion Parts
$375 Boxster S shifter and cables
$3000 Good used Boxster S transaxle
$175 Air Cleaner Kit
$180 Sport mount kit for trans
$120 Poly mounts for engine
$750 GPS speedometer upgrade (do I really need this??)
bulitt
post May 14 2014, 06:01 AM
Achtzylinder
Nothing against the kit manufacturers but IMHO this is the route I would take.
Cheapest solution- purchase a completed LS conversion.
Put a kit together- some estimates.
Motor- As Bigkat said- cheaper new from GM. Or just buy one off CL, or purchase a wrecked Camaro. 3000-5000$ Make sure you get the TB and Computer, exhaust manifolds, air filter. The Intake & TB gets mounted backwards with the air filter vented into the trunk as example.
Adapter and clutch @ 1000$ from KEP
Engine bar- 200$ from the kit guys
Transaxle relocating offsets- 20$ worth of metal, drilled.
Lengthen Shifter- 5$ in parts, DIY weld.
Plastic Overflow tank - 10$ Ebay
Aluminum expansion tank - 40$ Jegs/Summit/Dedenbear.
Electric Water Pump- 250$/Dedenbear
Toy-Jet water manifold (replace the water pump)- 250$
Yellow stripe hoses- 80$ NAPA
Radiator- 180$ - Ebay
Fans- 60$ Ebay
Hose transitions - 30$ from Jags that run.
High torque starter- 200$ Ebay
GPS Speedo- 170$- Speedhut
Do your research, read as many threads as you can, go look at some completed cars. troll the classifieds for conversion parts. Save some money! Have fun.
partwerks   Basic parts list   May 12 2014, 08:12 PM
speed metal army   Do it!   May 12 2014, 09:27 PM
Mike Bellis   My parts list: Cayman S 6 speed, shipped to my doo...   May 12 2014, 09:27 PM
partwerks   I'm would think some of this stuff could be go...   May 13 2014, 03:41 AM
BIGKAT_83   In terms of cost, here’s a basic parts list fro...   May 13 2014, 06:13 AM
CptTripps   :agree: that $21K seems pretty high. If you...   May 13 2014, 06:22 AM
stugray   Holy Crap! I'll sell you one for $1...   May 13 2014, 07:14 AM
partwerks   Does the Boxster S trans have cable driven speedom...   May 13 2014, 10:07 PM
Mike Bellis   Does the Boxster S trans have cable driven speedo...   May 13 2014, 10:10 PM
partwerks   Does the Boxster S trans have cable driven speed...   May 14 2014, 04:33 AM
bulitt   Nothing against the kit manufacturers but IMHO thi...   May 14 2014, 06:01 AM
partwerks   Some of the stuff I may be able to use from the WR...   May 14 2014, 09:54 PM
partwerks   Some of the stuff I can probably use from the Subi...   May 15 2014, 08:24 PM
BIGKAT_83   Some of the stuff I can probably use from the Sub...   May 16 2014, 04:24 AM
bulitt   [quote name='partwerks' post='2038022' date='May ...   May 16 2014, 05:26 AM
partwerks   [quote name='partwerks' post='2038022' date='May...   May 17 2014, 10:14 AM
partwerks   [quote name='partwerks' post='2038022' date='May...   Jul 4 2014, 10:45 PM
r_towle   you have a subaru conversion? why not save some m...   May 15 2014, 09:30 PM
partwerks   you have a subaru conversion? why not save some ...   May 16 2014, 06:41 AM
partwerks   2004 WRX 2.0   May 15 2014, 10:39 PM
r_towle   You could buy a newer engine for abut 6k from JDM ...   May 17 2014, 08:00 PM
partwerks   You could buy a newer engine for abut 6k from JDM...   May 17 2014, 11:40 PM
r_towle   You could buy a newer engine for abut 6k from JD...   May 22 2014, 01:45 PM
partwerks   I wonder how much chassis stiffening is required t...   May 19 2014, 06:29 AM
Mike Bellis   I wonder how much chassis stiffening is required ...   May 22 2014, 01:37 PM
partwerks   The guy at Kennedy told me the best trans would be...   May 22 2014, 06:50 AM
Mike Bellis   The guy at Kennedy told me the best trans would b...   May 22 2014, 01:36 PM
partwerks   1. The guy at Kennedy told me the best trans would...   May 31 2014, 03:07 PM
r_towle   EJ257[edit] EJ257 engine DOHC 16-valve turbo. Or...   May 22 2014, 01:47 PM
partwerks   When I called Kennedy eng., Clutch, flywheel, adap...   May 22 2014, 09:31 PM
Mike Bellis   Better gear ratios for V8 engines come from Audi T...   May 31 2014, 05:45 PM
partwerks   Better gear ratios for V8 engines come from Audi ...   May 31 2014, 06:43 PM
Mike Bellis   012 is a partial Audi part number. It is the trans...   May 31 2014, 11:44 PM
partwerks   Ok, so the two codes I am to look for, are: DQS, a...   Jun 1 2014, 07:33 AM
partwerks   Anyone have a install picture of the Boxster S, on...   Jun 7 2014, 09:58 PM
partwerks   Is the factory fuel tank used, if a electric fuel ...   Jun 12 2014, 09:18 PM
bulitt   Search Engines are your friends... :lol:   Jul 5 2014, 04:57 AM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:47 PM
