> Spark plug thread inserts., Should I be concerned?
Erben914
post May 13 2014, 11:15 PM
I have my engine out for a bear tub restoration. I am reassembling everything and almost ready to put the engine back in.
As I was cleaning things up replacing the tube seals and getting ready to adjust the valves I found these threaded sleeves in my spark plug holes. Attached Image Attached Image
Looks like a PO was a DA?
Did they strip all of the spark plug threads and use threaded inserts?
I probably wouldn't have even noticed but they are loose and partially back out when I took out the plugs.
They are at different depths now but do they bottom out when the plug is tight?
I can't tell because the base of the plug covers the sleeve when the plugs are in place.
I really don't want to take the heads off. I had no issues prior.
If it ain't broke don't fix it?
Or am I risking a bigger problem?
Cap'n Krusty
post May 14 2014, 11:45 AM
Cap'n Krusty
BTW, loose plugs, even plugs tight in loose inserts, can cause the exhaust gasses to torch right through the gap provided by their being loose. That's not something you want to have happen to your engine.
The Cap'n
Erben914   Spark plug thread inserts.   May 13 2014, 11:15 PM
Hawker   Well I'd say you just might be on to something...   May 13 2014, 11:24 PM
Erben914   Well I'd say you just might be on to somethin...   May 13 2014, 11:33 PM
Hawker   Well I'd say you just might be on to somethi...   May 14 2014, 09:14 AM
infraredcalvin   If they're loose, there is a problem, pay now ...   May 14 2014, 12:10 AM
Mblizzard   I had a car with the inserts and never had an issu...   May 14 2014, 05:34 AM
Joe Ricard   Time big insert. I had them in several HI Prefo...   May 14 2014, 05:49 AM
Cap'n Krusty   I disagree, Joe. If they're loose, they'r...   May 14 2014, 08:52 AM
JStroud   Eric, HP machine in Victor(Lodi), has done my mach...   May 14 2014, 09:02 AM
JStroud   Here you go, HP Engine and Machine ...   May 14 2014, 11:36 AM
Cap'n Krusty   BTW, loose plugs, even plugs tight in loose insert...   May 14 2014, 11:45 AM
Erben914   Thanks for all the input guys. I guess I won...   May 14 2014, 07:18 PM
Mblizzard   Thanks for all the input guys. I guess I won...   May 14 2014, 07:26 PM
JStroud   Damn Eric that's looking awesome, not bad for ...   May 14 2014, 07:40 PM
Erben914   [quote name='JStroud' date='May 14 201...   May 14 2014, 07:59 PM
Erben914   Thanks. I pulled it apart in November and was try...   May 14 2014, 07:49 PM
Erben914   Hey any tips on pulling the head? I know to keep t...   May 14 2014, 08:06 PM
Mblizzard   Hey any tips on pulling the head? I know to keep ...   May 14 2014, 08:20 PM
jmill   Had a single port VW motor overheat on me. Heads ...   May 14 2014, 08:14 PM
Erben914   Thanks for the advice. Here is what I found. Do y...   May 14 2014, 10:08 PM
Erben914   RE: Spark plug thread inserts.   May 14 2014, 10:10 PM
Mblizzard   Clean the area around the spark plugs and look for...   May 15 2014, 06:27 AM
Erben914   I couldn't find any cracks but two of the inse...   May 17 2014, 12:11 AM
- Lo-Fi Version Time is now: 25th December 2024 - 10:45 AM
