mr914 |
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None ![]() |
Pulling apart that Aluminum case 2.0 motor in anticipating to sell it and cant seem to get one of the heads off.
Motor has been sitting for 20 plus years and rotates freely. 4 heads came off with a little more than a ketchup bottle thump. 1 head came off with the cylinder attached The other one, wont seem to budge. Made sure all washers were removed. been soaking with PB Blaster for a couple of days BTW: motor had been sitting for several years and a mouse had made a nest on top of that particular cylinder. Hence - Mouse motor... Any suggestions? (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) ![]() ![]() |
Justinp71 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,588 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None ![]() ![]() |
More power! (IMG:style_emoticons/default/smash.gif) When I did mine I removed the entire assembly with the 3 heads and cam towers, some light prying was necessary, just be careful not to scratch any important surfaces. If your pulling the barrels off the pistons, maybe see if you can pull the head and barrel of together and then try to knock the barrel off with a mallet. |
Lo-Fi Version | Time is now: 28th June 2024 - 03:04 PM |
