> My turn at motorcycle Throttle bodies, making progress
Mark Henry
post May 10 2013, 10:57 AM
that's what I do!
Like I need another project... Beginning to be as bad as Dr Evil (IMG:style_emoticons/default/laugh.gif) ... (IMG:style_emoticons/default/huh.gif) ... (IMG:style_emoticons/default/unsure.gif)
I need some TB's for my 914/4 type 4 into bug project engine.
Jenvey, Extrudabody and TWM TB's are crazy frickin' expensive for what they are, so I'm going the Motorcycle TB route.
This is what came in the mail today, stuff looks real good (IMG:style_emoticons/default/piratenanner.gif)
Mark Henry
post May 15 2014, 10:52 AM
that's what I do!
Everything on this build is custom, between the engine and the car I'm betting 1500 hours.
Your friend is either going to bail on you, hate you or start charging you money.
I'm guessing, but I have at least 120 hours in the TB's alone. I didn't make templates.
At first things went fast enough that I thought about making and selling a few sets, but I think know it's not worth it.
Moneypit
post May 15 2014, 11:41 AM
QUOTE(Mark Henry @ May 15 2014, 11:52 AM) *
If anything my Friend would show me how to do things, not just do all the work. If I discover things deeply out of my pay grade I'd pay him. That, and there's a pretty solid welding/fabbing/machining presence up in this area. If I gan get back into 3d design stuff like CAD (used to use 3DS Max for game models), maybe someone can print them out on a 3d printer. If everything mates properly, then CNC out of aluminum? (IMG:style_emoticons/default/confused24.gif)
I figure this all would involve a lot of machining, especially in trying to get the TBs to align with and mate to the intakes, and especially getting the linkages sorted out! Then of course there's the fuel rails that would need to be correct for the TB's spacing, am I right? I see the issue of having to fab everything up.
In terms of the linkages, is it extremely complicated getting each pair of TBs slaved to each other? I was trying to think if you could rig up a system similar to Tangerine's pulley/slave style and have a TPS on the "master" TB?
Mark Henry   My turn at motorcycle Throttle bodies   May 10 2013, 10:57 AM
Mark Henry   Damn... you think they would get the spacing corre...   May 10 2013, 11:01 AM
Mark Henry   The bike injectors are shorter and I don't kno...   May 10 2013, 11:07 AM
Mark Henry   Take them all apart and i have 4 separate ITB...   May 10 2013, 11:09 AM
Mark Henry   Going to take a bit of :smash: but I'm thinki...   May 10 2013, 11:13 AM
Mark Henry   Going to take me a little bit to get going on this...   May 10 2013, 11:24 AM
SirAndy   Debating on You should get a set of these: http:...   May 10 2013, 11:35 AM
Mark Henry   Debating on You should get a set of these: http...   May 10 2013, 11:41 AM
bulitt   Going to take me a little bit to get going on thi...   May 10 2013, 02:44 PM
worn   Like I need another project... Beginning to be as...   May 10 2013, 11:43 AM
Mark Henry   Like I need another project... Beginning to be a...   May 10 2013, 12:27 PM
Randal   Mike Mueller was messing with bike TB's years ...   May 10 2013, 12:18 PM
Dr Evil   This is a project I want to do in the future as we...   May 10 2013, 02:32 PM
Dr Evil   Or mill of the flange of the manifolds and use a r...   May 10 2013, 02:47 PM
Phoenix-MN   Or mill of the flange of the manifolds and use a ...   May 10 2013, 03:53 PM
Randal   Or mill of the flange of the manifolds and use a ...   May 10 2013, 05:06 PM
rick 918-S   Lots of chatter about ITB's. I'm researchi...   May 10 2013, 05:05 PM
kevin311   What size engine are these going on? What are th...   May 10 2013, 07:07 PM
Phoenix-MN   What size engine are these going on? What are t...   May 10 2013, 08:14 PM
Elliot Cannon   What will be used to trigger the injectors?   May 10 2013, 07:09 PM
Mark Henry   What will be used to trigger the injectors? I a...   May 10 2013, 08:18 PM
rick 918-S   What will be used to trigger the injectors? I ...   May 10 2013, 08:37 PM
kg6dxn   You need some of these... http://www.914world.com...   May 10 2013, 07:21 PM
McMark   Just got a sextet of ITBs for my new 2.4 engine. ...   May 10 2013, 09:29 PM
Mark Henry   Just got a sextet of ITBs for my new 2.4 engine. ...   May 11 2013, 06:04 AM
crash914   Just get Evil to weld you up some manifolds like h...   May 11 2013, 08:00 AM
rick 918-S   Cast aluminum sometimes is tricky to weld. I'v...   May 11 2013, 08:04 AM
McMark   Came to my senses a little bit. Ordered one of th...   May 11 2013, 10:24 AM
r_towle   I love the title of the thread.....just cause its ...   May 11 2013, 07:28 PM
JamesM   Like I need another project... Beginning to be as...   May 12 2013, 09:01 AM
McMark   Sorry if we've totally :hijacked: you Mark. ...   May 12 2013, 10:02 AM
sixnotfour   Sorry if we've totally :hijacked: you Mark. ...   May 12 2013, 12:50 PM
stugray   98, 99 Suzuki GSXR 750. http://www.ebay.com/itm...   May 12 2013, 12:00 PM
Mark Henry   Sorry if we've totally :hijacked: you Mark. ...   May 12 2013, 04:12 PM
McMark   Polaris 650 TBs. I'm reconsidering since they...   May 12 2013, 08:50 PM
Mark Henry   I didn't like the funky shape on the bottom of...   May 15 2013, 02:31 PM
Eric_Shea   Send those to Evil... he can weld them up for ya...   May 15 2013, 02:34 PM
Dr Evil   Send those to Evil... he can weld them up for y...   May 15 2013, 07:48 PM
MDG   Send those to Evil... he can weld them up for y...   May 16 2013, 08:50 AM
Mark Henry   I was making good progress, but work got in the wa...   Nov 21 2013, 07:38 PM
Mark Henry   ITB without filters   Nov 21 2013, 07:40 PM
Mark Henry   ITB with filters   Nov 21 2013, 07:41 PM
Mark Henry   down the throat. I am having issues with clearanc...   Nov 21 2013, 07:46 PM
r_towle   Flip them, put the rail in the inside   Nov 21 2013, 08:50 PM
Mark Henry   Flip them, put the rail in the inside You reall...   Nov 21 2013, 09:50 PM
Dr Evil   Mark, you need to place them so that air will past...   Nov 21 2013, 10:15 PM
Mark Henry   Mark, you need to place them so that air will pas...   Nov 21 2013, 10:20 PM
gereed75   Mark, Have you seen this - vwmegasquirt.tk ...   Nov 26 2013, 10:13 PM
Mark Henry   Mark, Have you seen this - vwmegasquirt.tk ...   Nov 27 2013, 04:32 AM
kevin311   Please finish this!! For all of us that st...   Nov 27 2013, 06:09 AM
Mark Henry   I'll keep working it but it might be spring by...   Nov 27 2013, 09:14 AM
Mark Henry   I did some re-profiling on the 1/2 side fuel rail ...   Nov 27 2013, 09:23 AM
r_towle   Not sure how it's going.... But.... Have you...   Feb 3 2014, 07:52 PM
rick 918-S   Ya, what about cutting down the intakes?   Feb 4 2014, 09:04 AM
rdauenhauer   Question: is it better to have the injector nozzel...   Feb 4 2014, 09:08 AM
TeenerTim   Question: is it better to have the injector nozze...   Feb 4 2014, 04:07 PM
Mark Henry   Question: is it better to have the injector nozze...   Feb 4 2014, 04:42 PM
r_towle   Are you doing ITB's on the six you are buildin...   Feb 6 2014, 09:22 AM
Mark Henry   Are you doing ITB's on the six you are buildi...   Feb 6 2014, 11:17 AM
Mark Henry   It's alive :thumbsup:   May 14 2014, 11:24 AM
SirAndy   It's alive :thumbsup: :first:   May 14 2014, 11:48 AM
Moneypit   Pardon my noobiness, but as I understand this, usi...   May 14 2014, 01:04 PM
Mark Henry   More than just the sound, on an engine my size (10...   May 14 2014, 08:28 PM
crash914   Looks good Mark...very similar to my motor...103 x...   May 15 2014, 02:52 AM
bulitt   Wow :trophy:   May 15 2014, 05:04 AM
MrHyde   Awesome Mark !!! I'm gonna have to...   May 15 2014, 06:14 AM
rhodyguy   the fuch wheels look sharp on your t1.   May 15 2014, 07:39 AM
Mark Henry   I don't think it will need wheelie bars, she...   May 15 2014, 08:23 AM
Qarl   Post a video of it running... (and some throttle b...   May 15 2014, 08:24 AM
Moneypit   This is now relevant to my interests... I have car...   May 15 2014, 09:05 AM
Mark Henry   Everything on this build is custom, between the en...   May 15 2014, 10:52 AM
Moneypit   Everything on this build is custom, between the e...   May 15 2014, 11:41 AM
Mark Henry   [quote name='Mark Henry' post='2037804' date='May...   May 15 2014, 03:01 PM
crash914   Mark, I am using 30# per hour injectors in mine......   May 15 2014, 11:48 AM
- Lo-Fi Version Time is now: 20th April 2025 - 06:34 AM
