Condenser wire |
Condenser wire |
jmargush |
May 15 2014, 12:47 PM
Member Group: Members Posts: 465 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
Does the condenser wire on the distributor go to the + or - side of the coil?
toolguy |
May 15 2014, 01:36 PM
Senior Member Group: Members Posts: 1,275 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Does the condenser wire on the distributor go to the + or - side of the coil? negative Black/purple lead provides power to the coil on the positive side. Distributor is ground. Circuit is completed when the points close. Then juice is sent out of the high voltage wire from the coil to the spark plug. You might want to check a wiring diagram. . the condenser goes on the points {Usually green} lead which connects to the coil #1 lead with the Black Purple which goes to the tac input. . . the Blk/red is on coil term #15 which is the positive 12 volt power into the coil. . doesn't matter if the condenser is in the dizzy or mounted with the coil. . just wire to the negative points lead with the tac wire the purpose of the condenser is to absorb the voltage spike {the arc} when the point open. . the energy it absorbs is stored until the points close the next time and is then discharged into the coil, amplifying the spark. . often a weak spark is cause by a bad condenser |
Lo-Fi Version | Time is now: 6th January 2025 - 04:12 PM |
