Stuck 6 cyl head, No, its not stuck there.... |
mr914 |
May 15 2014, 11:12 AM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
Pulling apart that Aluminum case 2.0 motor in anticipating to sell it and cant seem to get one of the heads off.
Motor has been sitting for 20 plus years and rotates freely. 4 heads came off with a little more than a ketchup bottle thump. 1 head came off with the cylinder attached The other one, wont seem to budge. Made sure all washers were removed. been soaking with PB Blaster for a couple of days BTW: motor had been sitting for several years and a mouse had made a nest on top of that particular cylinder. Hence - Mouse motor... Any suggestions? (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
toolguy |
May 15 2014, 01:56 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
do not pry against the cylinder fins, they will break off easily. . If you're sure all 4 head nuts and washers are off, hit it with a RUBBER mallet. . it's better to tap many times than one hard time. . .
I was taught to hit on the top and bottom only which is the way the wrist pin/crank rotates. . . if you hit sideways it can bend the rod. . |
Jon B |
May 15 2014, 02:23 PM
Member Group: Members Posts: 73 Joined: 28-September 13 From: Vista, CA Member No.: 16,448 Region Association: None |
Lo-Fi Version | Time is now: 24th June 2024 - 11:34 PM |
