Condenser wire |
Condenser wire |
jmargush |
May 15 2014, 12:47 PM
Member Group: Members Posts: 465 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
Does the condenser wire on the distributor go to the + or - side of the coil?
toolguy |
May 15 2014, 01:36 PM
Senior Member Group: Members Posts: 1,275 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
Does the condenser wire on the distributor go to the + or - side of the coil? negative Black/purple lead provides power to the coil on the positive side. Distributor is ground. Circuit is completed when the points close. Then juice is sent out of the high voltage wire from the coil to the spark plug. You might want to check a wiring diagram. . the condenser goes on the points {Usually green} lead which connects to the coil #1 lead with the Black Purple which goes to the tac input. . . the Blk/red is on coil term #15 which is the positive 12 volt power into the coil. . doesn't matter if the condenser is in the dizzy or mounted with the coil. . just wire to the negative points lead with the tac wire the purpose of the condenser is to absorb the voltage spike {the arc} when the point open. . the energy it absorbs is stored until the points close the next time and is then discharged into the coil, amplifying the spark. . often a weak spark is cause by a bad condenser |
ClayPerrine |
May 15 2014, 03:25 PM
Life's been good to me so far..... Group: Admin Posts: 15,967 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
the purpose of the condenser is to absorb the voltage spike {the arc} when the point open. . the energy it absorbs is stored until the points close the next time and is then discharged into the coil, amplifying the spark. . often a weak spark is cause by a bad condenser That is not quite true. It does not amplify the spark, but it does absorb the voltage spike. Without a condenser, the voltage arcs across the points when the open, pitting the points and causing premature wear. Condenser: Those same principles of inductance create a kind of paradox, because when the points open and the magnetic field collapses it also induces a current in the primary as well. It's not very much because there are only a few windings in the primary, but it's enough to jump a small air-gap, such as the one between the just-opening points in the distributor. That tiny spark is enough to erode metal away from the points and you'll 'burn' the points. It prevents the points from arcing and prevents coil insulation breakdown by limiting the rate of voltage rise at the points. REF: http://autorepair.about.com/cs/generalinfo/a/aa052502a.htm |
Lo-Fi Version | Time is now: 6th January 2025 - 03:55 PM |
