Basic parts list |
Basic parts list |
partwerks |
May 12 2014, 08:12 PM
Senior Member Group: Members Posts: 1,599 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
In terms of cost, here’s a basic parts list from Renegade:
$8500 LS3 engine package 430hp (480hp $500 more) $2600 914 LS basic kit $2200 914 LS Boxster LS clutch and adapter upgrade $250 Starter $1200 Heavy Duty Axles $595 Rear Trans mount $750 Misc. Hydraulic Clutch Conversion Parts $375 Boxster S shifter and cables $3000 Good used Boxster S transaxle $175 Air Cleaner Kit $180 Sport mount kit for trans $120 Poly mounts for engine $750 GPS speedometer upgrade (do I really need this??) |
partwerks |
May 15 2014, 08:24 PM
Some of the stuff I can probably use from the Subie conversion, and some things I was able to look up, but some I'm not able to put the face to it.
Adapter and clutch @ 1000$ from KEP Engine bar- 200$ from the kit guys Transaxle relocating offsets- 20$ worth of metal, drilled. Toy-Jet water manifold (replace the water pump)- 250$ Hose transitions - 30$ from Jags that run. High torque starter- 200$ Ebay |
BIGKAT_83 |
May 16 2014, 04:24 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Some of the stuff I can probably use from the Subie conversion, and some things I was able to look up, but some I'm not able to put the face to it. Adapter and clutch @ 1000$ from KEP Engine bar- 200$ from the kit guys Transaxle relocating offsets- 20$ worth of metal, drilled. Toy-Jet water manifold (replace the water pump)- 250$ Hose transitions - 30$ from Jags that run. High torque starter- 200$ Ebay The Kennedy adapter for the Boxster transaxle alone is $1900. This is without the clutch Kit. You can use a stock Porsche one at $650 or the Kennedy one at $950. You can get all of the water pump fittings from Meziere and the remote pump. This will be almost $1000. Stuff adds up fast. Makes keeping the Subaru engine look better. If I was you I'd spend about $1000 and just put a Subaru transaxle in your car. It will feel like a different car with this. Bob |
bulitt |
May 16 2014, 05:26 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Some of the stuff I can probably use from the Subie conversion, and some things I was able to look up, but some I'm not able to put the face to it. Adapter and clutch @ 1000$ from KEP Engine bar- 200$ from the kit guys Transaxle relocating offsets- 20$ worth of metal, drilled. Toy-Jet water manifold (replace the water pump)- 250$ Hose transitions - 30$ from Jags that run. High torque starter- 200$ Ebay The Kennedy adapter for the Boxster transaxle alone is $1900. This is without the clutch Kit. You can use a stock Porsche one at $650 or the Kennedy one at $950. You can get all of the water pump fittings from Meziere and the remote pump. This will be almost $1000. Stuff adds up fast. Makes keeping the Subaru engine look better. If I was you I'd spend about $1000 and just put a Subaru transaxle in your car. It will feel like a different car with this. Bob Wow that LS adapter for the boxster is $$$ wonder why so much more than the Ls/901 adapter? I went with the Dedenbear water pump- WP3 @314$ but you can catch discounts that bring them down @ 280$. Autoplicity.com Look for Mezieres on Craigslist, the boating community uses them. The log plenum from Toyjet I see is up to 350$ (IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968657.1.jpg) Jags that run.com hose adapters- (IMG:http://www.914world.com/bbs2/uploads_offsite/jagsthatrun.com-13632-1400240537.1.jpg) Renegade will sell you the engine bar- (IMG:http://www.914world.com/bbs2/uploads/post-3419-1314666698.jpg) Here is a list of conversions. Look for build threads by member name. http://www.914world.com/bbs2/index.php?sho...c=20374&hl= |
Lo-Fi Version | Time is now: 6th January 2025 - 08:47 PM |
