> Basic parts list
partwerks
post May 12 2014, 08:12 PM
In terms of cost, here’s a basic parts list from Renegade:
$8500 LS3 engine package 430hp (480hp $500 more)
$2600 914 LS basic kit
$2200 914 LS Boxster LS clutch and adapter upgrade
$250 Starter
$1200 Heavy Duty Axles
$595 Rear Trans mount
$750 Misc. Hydraulic Clutch Conversion Parts
$375 Boxster S shifter and cables
$3000 Good used Boxster S transaxle
$175 Air Cleaner Kit
$180 Sport mount kit for trans
$120 Poly mounts for engine
$750 GPS speedometer upgrade (do I really need this??)
partwerks
post May 15 2014, 08:24 PM
Some of the stuff I can probably use from the Subie conversion, and some things I was able to look up, but some I'm not able to put the face to it.
Adapter and clutch @ 1000$ from KEP
Engine bar- 200$ from the kit guys
Transaxle relocating offsets- 20$ worth of metal, drilled.
Toy-Jet water manifold (replace the water pump)- 250$
Hose transitions - 30$ from Jags that run.
High torque starter- 200$ Ebay
BIGKAT_83
post May 16 2014, 04:24 AM
QUOTE(partwerks @ May 15 2014, 10:24 PM) *
The Kennedy adapter for the Boxster transaxle alone is $1900. This is without the clutch Kit. You can use a stock Porsche one at $650 or the Kennedy one at $950.
You can get all of the water pump fittings from Meziere and the remote pump. This will be almost $1000.
Stuff adds up fast. Makes keeping the Subaru engine look better.
If I was you I'd spend about $1000 and just put a Subaru transaxle in your car. It will feel like a different car with this.
Bob
bulitt
post May 16 2014, 05:26 AM
Achtzylinder
QUOTE(BIGKAT_83 @ May 16 2014, 06:24 AM) *
Bob
Wow that LS adapter for the boxster is $$$ wonder why so much more than the Ls/901 adapter?
I went with the Dedenbear water pump- WP3 @314$ but you can catch discounts that bring them down @ 280$. Autoplicity.com
Look for Mezieres on Craigslist, the boating community uses them.
The log plenum from Toyjet I see is up to 350$
(IMG:http://www.914world.com/bbs2/uploads_offsite/i60.photobucket.com-3782-1397968657.1.jpg)
Jags that run.com hose adapters-
(IMG:http://www.914world.com/bbs2/uploads_offsite/jagsthatrun.com-13632-1400240537.1.jpg)
Renegade will sell you the engine bar-
(IMG:http://www.914world.com/bbs2/uploads/post-3419-1314666698.jpg)
Here is a list of conversions. Look for build threads by member name.
http://www.914world.com/bbs2/index.php?sho...c=20374&hl=
partwerks
post May 17 2014, 10:14 AM
QUOTE(bulitt @ May 16 2014, 03:26 AM) *
Bob
I wonder on the engine bar, if i discontinue my engine bar for the Subie?
I could make the engine bar, maybe, if I had a pattern.
Also, how do I look up the members name/posts?
My mechnic showed me how to do the pipes with the water pump, as he is doing an ls conversion on a camaro.
partwerks   Basic parts list   May 12 2014, 08:12 PM
speed metal army   Do it!   May 12 2014, 09:27 PM
Mike Bellis   My parts list: Cayman S 6 speed, shipped to my doo...   May 12 2014, 09:27 PM
partwerks   I'm would think some of this stuff could be go...   May 13 2014, 03:41 AM
BIGKAT_83   In terms of cost, here’s a basic parts list fro...   May 13 2014, 06:13 AM
CptTripps   :agree: that $21K seems pretty high. If you...   May 13 2014, 06:22 AM
stugray   Holy Crap! I'll sell you one for $1...   May 13 2014, 07:14 AM
partwerks   Does the Boxster S trans have cable driven speedom...   May 13 2014, 10:07 PM
Mike Bellis   Does the Boxster S trans have cable driven speedo...   May 13 2014, 10:10 PM
partwerks   Does the Boxster S trans have cable driven speed...   May 14 2014, 04:33 AM
bulitt   Nothing against the kit manufacturers but IMHO thi...   May 14 2014, 06:01 AM
partwerks   Some of the stuff I may be able to use from the WR...   May 14 2014, 09:54 PM
partwerks   Some of the stuff I can probably use from the Subi...   May 15 2014, 08:24 PM
BIGKAT_83   Some of the stuff I can probably use from the Sub...   May 16 2014, 04:24 AM
bulitt   [quote name='partwerks' post='2038022' date='May ...   May 16 2014, 05:26 AM
partwerks   [quote name='partwerks' post='2038022' date='May...   May 17 2014, 10:14 AM
partwerks   [quote name='partwerks' post='2038022' date='May...   Jul 4 2014, 10:45 PM
r_towle   you have a subaru conversion? why not save some m...   May 15 2014, 09:30 PM
partwerks   you have a subaru conversion? why not save some ...   May 16 2014, 06:41 AM
partwerks   2004 WRX 2.0   May 15 2014, 10:39 PM
r_towle   You could buy a newer engine for abut 6k from JDM ...   May 17 2014, 08:00 PM
partwerks   You could buy a newer engine for abut 6k from JDM...   May 17 2014, 11:40 PM
r_towle   You could buy a newer engine for abut 6k from JD...   May 22 2014, 01:45 PM
partwerks   I wonder how much chassis stiffening is required t...   May 19 2014, 06:29 AM
Mike Bellis   I wonder how much chassis stiffening is required ...   May 22 2014, 01:37 PM
partwerks   The guy at Kennedy told me the best trans would be...   May 22 2014, 06:50 AM
Mike Bellis   The guy at Kennedy told me the best trans would b...   May 22 2014, 01:36 PM
partwerks   1. The guy at Kennedy told me the best trans would...   May 31 2014, 03:07 PM
r_towle   EJ257[edit] EJ257 engine DOHC 16-valve turbo. Or...   May 22 2014, 01:47 PM
partwerks   When I called Kennedy eng., Clutch, flywheel, adap...   May 22 2014, 09:31 PM
Mike Bellis   Better gear ratios for V8 engines come from Audi T...   May 31 2014, 05:45 PM
partwerks   Better gear ratios for V8 engines come from Audi ...   May 31 2014, 06:43 PM
Mike Bellis   012 is a partial Audi part number. It is the trans...   May 31 2014, 11:44 PM
partwerks   Ok, so the two codes I am to look for, are: DQS, a...   Jun 1 2014, 07:33 AM
partwerks   Anyone have a install picture of the Boxster S, on...   Jun 7 2014, 09:58 PM
partwerks   Is the factory fuel tank used, if a electric fuel ...   Jun 12 2014, 09:18 PM
bulitt   Search Engines are your friends... :lol:   Jul 5 2014, 04:57 AM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 08:35 PM
