mr914 |
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None ![]() |
Pulling apart that Aluminum case 2.0 motor in anticipating to sell it and cant seem to get one of the heads off.
Motor has been sitting for 20 plus years and rotates freely. 4 heads came off with a little more than a ketchup bottle thump. 1 head came off with the cylinder attached The other one, wont seem to budge. Made sure all washers were removed. been soaking with PB Blaster for a couple of days BTW: motor had been sitting for several years and a mouse had made a nest on top of that particular cylinder. Hence - Mouse motor... Any suggestions? (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) ![]() ![]() |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
I have had the same problem, and cut the stud...BTW that appears to have 90mm cylinders, 2519cc , the case has been bored to accept them, heads modified also to accept the bigger bore and later head gasket, or they are later heads, what is the casting year number on them ??
Good Score ..unless you wanted a 2.0-2.4.... Better Decode the engine number, It may be worth way more than you think...911S registry guys are always searching for these early motors these days to complete their numbers matching desire..$$$$ One more thing if that Red fan shroud is correct its a S motor .....$$$ |
Lo-Fi Version | Time is now: 28th June 2024 - 03:33 PM |
