Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I have a line on the OEM vinyl from Germany that's correct for our cars. The material that I'm currently using is pretty close, but not 100%. It is a domestic product that is of reasonable quality, but for the purists or those that don't want to pay $70+ from other sources, this is the stuff.
I have to bring in a full roll, so it's a significant investment, but I think it's worth it. I'll get pictures up of the material on Friday. This will take about a month before I have material, but who wants it? |
Mikey914 |
Good news the material is here. We've started processing it and will be able to ship starting Friday!
As usual I have made some improvements. The pieces are precision cut for an easier installation. We have cut kerfs at the rear section of the pieces, making them easier to stretch down where material normally bunches up more. The real kicker is we have put the holes in the material at the base so that the sail trim can easily be installed. If you are going commando on the trim, you can easily trim the bottom lip 1/8" and install. We do highly recommend using the trim as it helps to keep the edge down. You can find them here - http://www.shop.914rubber.com/914-Sail-Vin...-cut-914GSV.htm Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 08:21 PM |
