Portia |
Newbie ![]() Group: Members Posts: 7 Joined: 25-May 14 From: Omaha, NE Member No.: 17,396 Region Association: None ![]() |
Hello, everyone! I am new to the forum, and to 914s. I just dragged home a 1973 914 1.7L that has been in storage for 27 years, and not started during that time. (It was owned by one man since 1974.) It is in need of inner rocker replacement and door sill/jamb replacement on the passenger side as well.
The goal of the project is to make it safe and get it running while keeping it as original as possible for as little money as possible. Last night my husband and I pulled the gas tank preparatory to replacing the fuel lines. The car was put into storage out of gas, fortunately. The tank looks good from the outside. Should we get it boiled out and sealed, or is this an unneccessary expense? If we don't do that, I will probably use POR15's cleaner and degreaser with a quart of hot water to clean it. Photos: (IMG:http://www.914world.com/bbs2/uploads_offsite/i603.photobucket.com-17396-1401031248.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i603.photobucket.com-17396-1401031249.2.jpg) Tank: (IMG:http://www.914world.com/bbs2/uploads_offsite/i603.photobucket.com-17396-1401031249.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i603.photobucket.com-17396-1401031249.4.jpg) I'm sure I'll have other questions as the resurrection continues. Thanks! (IMG:style_emoticons/default/bye1.gif) |
Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,032 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
(IMG:style_emoticons/default/agree.gif) Take a look inside. It might be fine in there. Mine was like new when I looked at it last year.
And (IMG:style_emoticons/default/welcome.png) |
Portia |
Thanks, everyone. Now should I replace the clear plastic lines that run from the brake reservoir to the master? There is no fluid in the reservoir or the lines, so they may be cracked down below, but the brakes do work - at very slow speeds, anyway - so I guess the level must just be very low.
If so, what should I replace them with? Is there anything else I should do before the tank goes back in? |
Lo-Fi Version | Time is now: 26th June 2024 - 12:25 AM |
