boxsterfan |
914's are kewl ![]() ![]() ![]() Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California ![]() |
First off, I am not anywhere near an expert in engine building, cam selection (how duration and lift affect the motor at idle and driving), injector flow rates, etc, etc, etc... So now that I have that out of the way, I still want to figure out the bits and parts that ***may*** make it possible to run a 2270 motor with LH-Jet. The primary reasons I am looking at this setup are because:
From my research, LH-Jet 1.0 was pretty rare and used in the early 80's but then a switch to LH-Jet 2.0 occured. The primary difference between the two was that LH-Jet 2.0 utilized a Throttle Position Sensor (TPS) whereas LH-Jet 1.0 did not. 2. If LH-Jet 2.0 variant is the desired setup, which sub-variant would be used? There appears to be a couple sub-variants within LH-Jet 2.0 primarily consisting of LH-Jet 2.2 and LH-Jet 2.4. It appears one of the primary differences between the two is that the LH-Jet 2.4 utilizes a "trigger flywheel" and the LH-Jet 2.2 does not. What exactly a "trigger flywheel" is I am not sure....I am guess that this is a notch or mark on the flywheel that is monitored by a sensor with the data fed back to the ECU. 3. What would the "build" sheet look like for such a setup? Of course, this list can get complicated, but the desired build here is a street car with spirited driving. I would want excellent low-end torque, around 140-150HP on the motor and good pull all the way through the RPM range up to XXXX RPM (not sure where redline would be). Note also, the car will remain as a narrow body with 4-lug wheels.
MrKona |
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None ![]() |
LH-Jet 2.2 cold start valve is controlled by the ECU with input from the coolant temp sensor. There is no thermo time switch. If sticking with the original ECU, what signal could be used as an input in lieu of the coolant temp sensor?
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
LH-Jet 2.2 cold start valve is controlled by the ECU with input from the coolant temp sensor. There is no thermo time switch. If sticking with the original ECU, what signal could be used as an input in lieu of the coolant temp sensor? CHT could provide the input, but you would need to design some electronics to bring the CHt readings inline with a coolant temp sensor. Coolant gets to what...180 degrees.. A CHt can get to 380.... Probably need to figure t what a coolant temp sensor reads at different temps on the stove.. |
MrKona |
LH-Jet 2.2 cold start valve is controlled by the ECU with input from the coolant temp sensor. There is no thermo time switch. If sticking with the original ECU, what signal could be used as an input in lieu of the coolant temp sensor? CHT could provide the input, but you would need to design some electronics to bring the CHt readings inline with a coolant temp sensor. Coolant gets to what...180 degrees.. A CHt can get to 380.... Probably need to figure t what a coolant temp sensor reads at different temps on the stove.. Any thoughts about the oil temp sensor at the taco plate? |
Lo-Fi Version | Time is now: 25th June 2024 - 10:35 PM |
