Mikedrevguy |
Member ![]() ![]() Group: Members Posts: 87 Joined: 19-May 14 From: Medford, Or Member No.: 17,371 Region Association: Pacific Northwest ![]() |
Picked up a 76 2.0 for my better 1/2.
It's been off the road for the past -10 years. Motor spins freely and, reportedly, was rebuilt shortly before it was parked (which was due to physical limitations). Paint is heavily oxidized. Brakes were locked up, rotors rust covered. Car had been hit previously, and the resulting bondo has cracked pretty badly. Interior is nice, seats have no tears or holes. Dash has a couple cracks, but nothing overly grotesque. As I begin getting this back roadworthy, Am pulling fuel tank to be cleaned out thoroughly. Replacing all fuel and vacuum lines. Changing oil and trans fluid. Will go through brake system. See what's good. What's in need of replace or [email]repair. My question: where can I go for a list of what pieces parts are compatible from year to year in the 914. Interested in front and rear hoods, top, brake calipers - Or more specifically, I've a line on a 71 running complete parts car- what will cross over between a 71 and a 76? Thanks. I look forward to posting pics (when I get them and figure out how they work on this forum. Rev. |
Mikedrevguy |
And rear rotors mic out at - 9.75mm
Fronts - 10.4 & 10.2 That's before being turned. |
Mikedrevguy |
And rear rotors mic out at - 9.75mm Fronts - 10.4 & 10.2 That's before being turned. So it pays to read, completely, all the parts, charts, graphs, and the check to make sure there isn't anything that's been missed. rotor thickness Looked up info on wear limits for rotors. Wanted to see if they were within tolerances not. Followed the link, read the chart and simply presumed that front and rear rotors had same dimensions. Foolish naive, whatever. Armed with this misinformation. I set ant pricing out rear rotors, believing they were out of spec. Yestereve, I read further and discovered the chart for the rear rotor specs which puts these certainly within tolerances. Again- read. Reread. And read some more. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:19 AM |
