RevWife's 914, Pulling a 914 back onto the road |
Mikedrevguy |
May 19 2014, 09:34 AM
Member Group: Members Posts: 87 Joined: 19-May 14 From: Medford, Or Member No.: 17,371 Region Association: Pacific Northwest |
Picked up a 76 2.0 for my better 1/2.
It's been off the road for the past -10 years. Motor spins freely and, reportedly, was rebuilt shortly before it was parked (which was due to physical limitations). Paint is heavily oxidized. Brakes were locked up, rotors rust covered. Car had been hit previously, and the resulting bondo has cracked pretty badly. Interior is nice, seats have no tears or holes. Dash has a couple cracks, but nothing overly grotesque. As I begin getting this back roadworthy, Am pulling fuel tank to be cleaned out thoroughly. Replacing all fuel and vacuum lines. Changing oil and trans fluid. Will go through brake system. See what's good. What's in need of replace or [email]repair. My question: where can I go for a list of what pieces parts are compatible from year to year in the 914. Interested in front and rear hoods, top, brake calipers - Or more specifically, I've a line on a 71 running complete parts car- what will cross over between a 71 and a 76? Thanks. I look forward to posting pics (when I get them and figure out how they work on this forum. Rev. |
jim_hoyland |
May 26 2014, 08:28 PM
Get that VIN ? Group: Members Posts: 9,332 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Fuel Tank: there is a copper filter under inside the tank outlet. It's shaped like a sock and designed to keep particles from reaching the fuel pump. You may need a pointed tool to loosen and remove it for cleaning. I just did this and found a fair amount of sediment in the screen; from the look of your fuel gauge sender, there could be a buildup. BTW, the screen are available new if it's really bad
Good luck with the project |
Lo-Fi Version | Time is now: 20th June 2024 - 06:16 AM |
