Jetsetsurfshop |
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States ![]() |
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running 2258cc 10.5 to 1 compression 40 webers 494 web cam type 1 oil pump mocal oil cooler 25 row mocal sandwich w/thermostat adapter accusump 2 quart Brad Penn Air-cooled oil 15-50 (5 1/2 quarts) Let me explain my set-up The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible. Track conditions Sunny, low 80s, 30min sessions question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable? question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side. It only happens under WOT. Any ideas? question 3) I never set-up an accusump and I don't like it so far. It over fills the case at shut-off. Do I have to much air in it (9lbs)? Other then my oil questions, I had a great time. Ran a 2:51. My new best time. (IMG:style_emoticons/default/smilie_pokal.gif) |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
nice work....
I built something similar for my tranny I just couldn't get enough clean air at the edge of the firewall (where yours is) I ended up moving my intake scoop to the passenger side window and taking the duct work down through the engine lid and into the rear trunk dropped my trans temp another 15 -20 degree's when I moved my scoop Attached image(s) ![]() |
Jetsetsurfshop |
nice work.... I built something similar for my tranny I just couldn't get enough clean air at the edge of the firewall (where yours is) I ended up moving my intake scoop to the passenger side window and taking the duct work down through the engine lid and into the rear trunk dropped my trans temp another 15 -20 degree's when I moved my scoop I borrowed your idea here. I never noticed an update on your thread about it working or not working. Mine doesn't have that elbow that your does. I don't know if that will make any difference or not. I'll find out at Sebring in June. It will be hot!! Shane |
Lo-Fi Version | Time is now: 26th June 2024 - 08:15 PM |
