recent Sebring Abuse, Oil system help |
Jetsetsurfshop |
Dec 17 2013, 10:32 AM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Everyone (IMG:style_emoticons/default/biggrin.gif)
Here's what I'm running 2258cc 10.5 to 1 compression 40 webers 494 web cam type 1 oil pump mocal oil cooler 25 row mocal sandwich w/thermostat adapter accusump 2 quart Brad Penn Air-cooled oil 15-50 (5 1/2 quarts) Let me explain my set-up The oil cooler is a rear mount under the car on the passenger side rear. I made some duct work and its almost vertical to catch the most air as possible. Track conditions Sunny, low 80s, 30min sessions question 1) With that cooler I didn't expect to run in the 230f oil temps. Is 230f acceptable? question 2) I also have some oil on the top of the case /engine tin pooling. 1-2 side. It only happens under WOT. Any ideas? question 3) I never set-up an accusump and I don't like it so far. It over fills the case at shut-off. Do I have to much air in it (9lbs)? Other then my oil questions, I had a great time. Ran a 2:51. My new best time. (IMG:style_emoticons/default/smilie_pokal.gif) |
Seabird |
May 28 2014, 07:51 AM
Member Group: Members Posts: 165 Joined: 21-November 13 From: United States Member No.: 16,683 Region Association: South East States |
I was under the impression that the tumbling air under the cylinder heads, caused by the plastic flaps, was important for head cooling. By adding this ducting here under the 3/4 bank are you not exacerbating the cooling challenges to cylinder 3?
I may not be getting a clear understanding of the layout from the pictures. Miguel |
Jetsetsurfshop |
May 28 2014, 09:40 AM
I was under the impression that the tumbling air under the cylinder heads, caused by the plastic flaps, was important for head cooling. By adding this ducting here under the 3/4 bank are you not exacerbating the cooling challenges to cylinder 3? I may not be getting a clear understanding of the layout from the pictures. Miguel I removed those flaps a while ago. They were falling off with the rust I had there. I've run the car for a while now and my head temp is fine. I will monitoring head temps with the tubing there. I guess it could run up a bit. See you next Sunday. (IMG:style_emoticons/default/smile.gif) Shane |
Seabird |
May 28 2014, 09:41 AM
I was under the impression that the tumbling air under the cylinder heads, caused by the plastic flaps, was important for head cooling. By adding this ducting here under the 3/4 bank are you not exacerbating the cooling challenges to cylinder 3? I may not be getting a clear understanding of the layout from the pictures. Miguel I removed those flaps a while ago. They were falling off with the rust I had there. I've run the car for a while now and my head temp is fine. I will monitoring head temps with the tubing there. I guess it could run up a bit. See you next Sunday. (IMG:style_emoticons/default/smile.gif) Shane Yeah man I am stoked!! Watching everyone race this weekend was frustrating! |
Lo-Fi Version | Time is now: 27th September 2024 - 07:59 PM |
